Ice water pump torque specs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, May 12, 2014.
  1. JC91006
    16,672
    8,518
    I was reading some info on the torque specs on the ice water pump, it says to tighten to 8 ft lbs of torque. Can that be right? I remembered when I did mine, I hand tighten but surely I did more than 8 ft lbs. Hopefully that won't mess anything up.
  2. Mendel Leisk
    40,575
    What's the size of the socket used to drive the bolts in question? That'll help clarify, because 8 foot pounds is crazy low. Spark plugs, by comparison are 15~20 foot pound, and they're one of the lowest torque specs. Maybe you're misreading the torque values?
    BTW, how about "engine coolant pump", instead of "Ice water pump"? Something about the latter is confusing the hell out me, lol.
  3. Patrick Wong
    18,200
    6,492
    It is true that the three bolts and two nuts that secure the engine coolant pump should be tightened to 8.1 ft-lb while the three pulley bolts should be tightened to 11 ft.-lb. A 10 mm size wrench is used.
  4. JC91006
    16,672
    8,518
    I'm wondering if the low torque specs are the reason why so many pumps leak. 8ft lb Is something a 5 year old can do
    SM-N900P ?
  5. Patrick Wong
    18,200
    6,492
    If that were true, the leak would come around the coolant pump gasket. I don't believe that is a significant issue.
    Brute strength usually is not needed to service the Prius, but a reasonable amount of judgment is required.
  6. JC91006
    16,672
    8,518
    I understand that brute strength is not necessary but for the engineers to only require 8 ft lbs for an engine part, it just seems odd. Remember this is driven by a belt and spinning constantly. That vibration and constant spinning should easily loosen something that's only tighten to 8ft lbs, imagine a wheel, 5 lug nuts tightened considerably more. I'm not an engineer just trying to see how that thinking came about on their part. Just the fact that it doesn't come apart at 8ft lbs is amazing.
  7. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Check the repair manual to see if the gasket material is an adhesive sealant rather than paper material.
    Adhesive type sealant does not require high torque.
  8. JC91006
    16,672
    8,518
    If I'm not mistaken the gasket is just a simple paper type
  9. FazilHussein
    FazilHussein Member
    69
    36
    Perth, Ontario, Canada
    Yes, gasket is thin cardboard like material; was a pain to install. I dabbed a little rtv sealant to keep it stuck to the engine surface; otherwise, manipulating the water pump for install would knock it loose. The gasket that came off my car was metal.
  10. JC91006
    16,672
    8,518
    I can't remember a metal gasket from Toyota. I still have the old water pump somewhere in my garage. I'll have to look at that gasket. I can't remember it being a metal one.
  11. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Remember, OP, that it's just a 10mm bolt. 8ftlbs on a 10mm bolt head doesn't sound inconceivable.
  12. JC91006
    16,672
    8,518
    I didn't get a torque wrench in there, but even hand tightening I'm sure I did a minimum of 20ft lbs of torque on that thing.
  13. Mendel Leisk
    40,575
    I'd guestimate if you one-handed ratchet wrenched it, and weren't too aggressive, you'd be close. But if you held the center with one hand while tightening with the other you'd be somewhere between 10~20 foot pounds.
  14. Mr Incredible
    955
    506
    Neb
    Maybe with a wrench, but not 20 by hand.
    But just because you CAN doesn't mean you NEED to.
    Just sayin'. Once I got my own torque wrenches and was able to calibrate my wrench hand, I found I'd been overtightening things like crazy. I don't break and strip bolts hardly at all any more. Nor have I had any back out.
  15. JC91006
    16,672
    8,518
    So sorry, my meaning by hand tightening is by using a 10mm wrench and tighten by hand. No torque wrench to guide
  16. Patrick Wong
    18,200
    6,492
    The correct engine coolant pump gasket is black rubber-coated metal and no sealant is required.
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    When I replaced my water pump at 71K miles, I converted the 8 ft-lb value to inch-lb since my ft-lb wrench doesn't go any lower than 25. That would be 96 inch-lb. I also reused the original gasket, which as Patrick said is rubber coated metal. It was in perfect shape and I saw no reason why it couldn't be used again. And now 100K later it is still working fine with no leaks.
  18. Sonic_TH
    Sonic_TH Active Member
    568
    95
    Puerto Rico
    2016 Prius c
    So what is the torque spec for the engine water pump? 20 foot pounds?
  19. dolj
    dolj Senior Member
    8,212
    4,183
    Wellington, New Zealand
    I thought we agreed it was 8 ft-lbs, which is 11 Nm for the SI crowd.
    #19 dolj, Mar 25, 2021
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    Or 96 inch-lb on an inch-lb torque wrench. As stated, my ft-lb wrench starts at 25 ft-lb.
