I'd love to hear about your setup for storing/hanging charging cable
Discussion in 'Prime Plug-in Charging' started by wrenwren8, Dec 21, 2017.
  1. wrenwren8
    wrenwren8 New Member
    22
    Alden, NY
    I am planning on plugging my charging cable into the wall and leaving it plugged. I would love to hear about what setup/hardware people are using to hang it/store the cable on. It would be convenient to just grab the cable end and plug it into the car and vice versa.
    51,673
    i screwed a plastic flower pot onto the wall and hang it like a hose.
    if you don't want to coil and uncoil, lay it on a shelf like a snake.
  3. wrenwren8
    22
    Alden, NY
    I love that idea!
  4. Mark57
    2,945
    2,740
    OK
    Mine is coiled, laying on a shelf next to the electric plug so the weight of the large piece is not supported by the electric plug. Best thing is in your situation, find a way to support that weight instead of it trying to unplug itself. There are holes in each corner so you could support it by tying it to a nail with a string or piece of wire. You might want to take the cable with you some day so a permanent mount with screws t the wall might be too permanent.
  5. bisco
    51,673
    good point, i hung mine from with a small bungi cord to a hook in the wall.
    Mark57 likes this.
  6. Salamander_King
    Salamander_King Senior Member
    11,013
    8,942
    New England
    #6 Salamander_King, Dec 21, 2017
    Mendel Leisk and Mark57 like this.
  7. Salamander_King
    11,013
    8,942
    New England
    You also want to install a hook for CCID, like shown on the owner's manual.
    PrimeSkeptic likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    One side of my garage is lined with shelves. At the receptacle end, the CCID is hanging by a bungee from a shelf. The cable is strung along the floor and tucked under the shelves. The car end of it is simply draped over the front corner of the end of the shelves about two feet from the car's charging port. It ain't elegant, but it's extremely convenient. And free.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I highly recommend plugging a little 1ft extension into your outlet first, like this:
    Code:
    https://www.amazon.com/SF-Cable-Ultra-Profile-Angle/dp/B01N3Z26WA/ref=sr_1_1?s=industrial&ie=UTF8&qid=1513887080&sr=1-1&keywords=5-15r+to+5-15p+right+12%2F3
    I have one of these permanently hanging from outlets in the garages of many houses to charge my Leaf.
    The reason being outlets do wear out plugging in and out. I'd much rather replace the cable every so often vs. the outlet itself.
    Then you can 3D print a J1772 holder (or just but on Amazon) like this:
    Code:
    https://www.amazon.com/EV-Charger-Holster-Electric-Included/dp/B074DN623C/ref=sr_1_1_sspa?s=automotive&ie=UTF8&qid=1513887601&sr=1-1-spons&keywords=J1772+holster&psc=1
    Then to hold the EVSE itself, a little outlet shelf works well. But really, I just let it hang off the extension cord.
    Code:
    https://www.amazon.com/Outlet-Organizer-Storage-Office-Bathroom/dp/B01DQ146E0/ref=sr_1_9?ie=UTF8&qid=1513887688&sr=8-9&keywords=outlet+shelf
    Anthny likes this.
  10. MNdriver
    MNdriver Senior Member
    549
    577
    I only use the level 1 charger, but I leave it plugged in in my garage. It’s right next to a wire shelving rack I have sitting in front of my car, so I bought an 'over the door clothes hook’ that I hung from the shelf and I loop the cable over this hook to hang it.
    Mark57 and jerrymildred like this.
  11. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I just bought a hook at Lowe's. It's the kind that's designed to fit into a track, but it has screw holes which allowed it to be mounted directly to the wall:
    We located in on the back wall of the garage because I usually like to back in. But the cord is long enough to reach even when parked front in first. Also, it can reach most of the second bay of the garage if needed.
    To hook up the Prime, I usually just remove a couple of the coils of the cable. By leaving most of it on the hook, it's quick and easy to plug into the car and to put back.
    #11 Old Bear, Dec 27, 2017
  12. Old Bear
    712
    1,050
    Ooops... wrong image. This is the hook which I used (and which is shown in the photo of the EVSE):
  13. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
    I tapped off an exterior light between our garage doors to install below it a weatherproof exterior 120V outlet for charging. Just under it, I installed a screw eye, from which I hang the charger unit (using a key ring and spring link together):
    1948FFC9-44EC-4184-B9F7-224E8D571BA3.jpeg 68E12143-774E-4CD8-BB06-D8A1E780D209.jpeg
    panache, ruby, Anthny and 2 others like this.
  14. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    I have a similar hook with some carpet tiles running down the wall to the floor to stop the brick work from scraping against the cable when I frequently move it to us it.
    iPhone ?
  15. Old Bear
    712
    1,050
    That is a very elegant solution. And it's great that you used a weatherproof outlet with a cover that will allow the cord to come out through the bottom of the cover when it's closed. And a GFCI outlet, too!
    mercat68 likes this.
  16. mercat68
    311
    216
    Mount Airy, MD
    Yeah, not taking any chances with an outlet likely to be exposed to moisture. Due to the thickness/stiffness of the cord, the cover doesn’t quite close completely, but it closes enough to keep the rain off.
  17. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Just be sure to keep the cord off the ground as much as possible.
    Our house backs up to open farm land and a little creek. During winter, little critters try to get warm in the garage. Apparently, electrical cables are tasty! I had about a 2 inch section of a previous EVSE chewed down to the wire.
  18. MNdriver
    549
    577
    I charge in a garage but always lay the cable across the passenger side mirror to keep it off the ground.
    Francois and mercat68 like this.
  19. mercat68
    311
    216
    Mount Airy, MD
    Good advice!
  20. jerrymildred
    11,517
    14,147
    Tampa, FL
    We have had mice eat through Tupperware containers placed on shelves four feet above the floor. I don't think height is much of a deterrent. But it might help a little.
