Ideas? Misfire after head gasket repair
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Michael Cyr, Oct 24, 2024.
  1. Michael Cyr
    Michael Cyr Junior Member
    17
    Belgrade, ME
    I'm looking for ideas about the possible cause of my cylinder one misfires in my 2012 Prius. This car had a terrible head gasket leak between cylinder one and two. I replace the head gasket and cleaned the EGR cooler and valve. I did not have the head machined but cleaned it up with sandpaper on a thick piece of glass and checked it with a machinists rule and feel a gauges . I used a felpro head gasket . I cleaned the manifold including making sure the EGR passages were clear. I'm still getting cylinder one misfires on cold start up, including if the car sits for 4 or 5 hours. When doing the head gasket I checked the cylinder Heights looking for bent rod and they seemed the same. I have borescoped cylinder one when cold and scoped it with the radiator pressurized. No evidence of leaking. I've done a leak down test on all four cylinders and it's rock solid. I replaced all the plugs when I did the head gasket and have swap them around since with no change. I have swapped the injectors around and put a new Bosch coil on. No improvement. I've sprayed carb cleaner around all the Junctions of the air system looking for a vacuum leak to no avail. Could it be my ecm? I've got no codes except the occasional cylinder one misfire. Otherwise the car runs great and gets 46 miles per gallon. It is the wagon version. Any other ideas? Thanks in advance. Mike
    51,042
    did you clean the tiny intake manifold ports?
  3. Mendel Leisk
    40,498
    You've been very thorough.
    So it was showing P0301 before (cylinder one misfire), and still is?
  4. ASRDogman
    ASRDogman Senior Member
    7,134
    3,729
    If you swopped/replaced plugs and coils injectors.... Checked for vacuum leaks....
    Replaced the head gasket and ran a camera and see no coolant....
    I would "guess" perhaps the connector to #1 coil? Or in the harness....
  5. Michael Cyr
    17
    Belgrade, ME
    Yes, I think you're referring to the EGR ports in the manifold. All cleaned out and could blow air through all of them freely
  6. Michael Cyr
    17
    Belgrade, ME
    Yeah, that's what I was thinking but why would it be intermittent? It's behaving like a head gasket issue. But I also pressure tested the system to 15 psi and it held it for hours until I went to sleep last night. It went down maybe 1 psi over 2 hours which I put down to the crappy Harbor Freight connector for the reservoir for the test gauge. I did find a marginal connection on the injector for number one and fixed that. But that wasn't intermittent.
  7. Michael Cyr
    17
    Belgrade, ME
    Yes it had the P0301 before I did the head gasket. Now that code comes and goes as pending and only once or twice has graduated to a current code. So what I think is going on is that it sets a pending code after the misfire in the morning and then I might have five or six stops during the day and it ends up clearing itself. I was thinking about putting a scope on the fuel injection connector and the ignition coil connector and I have a cheap little scope that I bought recently from AliExpress but I've never used it and have no idea how to hook up a scope
  8. Michael Cyr
    17
    Belgrade, ME
    It's acting so much like the head gasket is still leaking but as far as I can tell it isn't. I even took a piece of paper towel on a piece of wire and stuff down inside the cylinder through the spark plug hole and rotated it all around and then pulled it out checking for any moisture. Oh and I forgot to mention I've done several combustion gas tests on the coolant. All were negative. Before I did the head gasket this car was blowing white steam out the tailpipe
  9. Michael Cyr
    17
    Belgrade, ME
    Here's another data point I just remembered. I did change the PCV valve when I did the head gasket. The old one was clicking when shook but a little sluggish so I changed it. I noticed the other day when I had the air hose off that the puddle of oil in the throttle body was back. I cleaned it out and then I checked it maybe three or four days later and there was quite a puddle again. So I ordered an oil catch can but haven't installed it yet. Is it likely that it's blowing excessive oil and that is temporarily fouling the plug on cylinder one? I would expect it to affect all the cylinders. I have gotten the occasional misfire on cylinder 2 but very rarely. I have a xtool d8 so I can monitor misfires in real time
  10. ASRDogman
    7,134
    3,729
    You said you sanded the head gasket.....
    It might be warped....Sanding was enough....
    If the wires aren't broken, or cracked, you're running out of things to check.
    I also have the D8. I really like it!
    Keep an eye on the coolant level. Try to match the conditions that you check it
    so it's always the same.
    I check my oil and coolant when I get fuel for the Prius. The coolant is alway higher
    than the full mark. And when it has sat overnight, it's just above the full mark.
    Michael Cyr likes this.
  11. Michael Cyr
    17
    Belgrade, ME
    I checked the head with a Machinists rule. I sanded the head not the head gasket. I thought about running it until it gets worse and possibly a more obvious cause.
  12. ASRDogman
    7,134
    3,729
    I realized I miss wrote... But it was too late to edit...
    "You said you sanded the head...
    It might be warped....Sanding wasn't enough...."
    Is what I meant to write.
    You could also possibly have a cracked head.
    I would also think maybe bad fuel, but since it's only one cylinder.... not likely.
    You know it won't fix itself, so driving it could make it worst and easier to find. (y)
  13. Michael Cyr
    17
    Belgrade, ME
    Thanks for staying with me on this. Regarding cracks I magnafluxed the combustion chamber check for cracks between the valves and around the spark plug. Forgot to mention that. Thanks for staying with me on this
    ASRDogman likes this.
  14. ASRDogman
    7,134
    3,729
    Well than pretty much the only thing is electrical.
    Maybe a bad ground? Very puzzeling....
    Unlessssss.... the block is damaged. Which is really unlikely.
    The head would go before the block.
  15. rjparker
    rjparker Tu Humilde Sirviente
    9,523
    5,827
    Texas Hill Country
    I seriously doubt it’s electrical or electrically controlled. It’s possible to have a cylinder to cylinder hg leak but that won’t cause a cold start shake that clears. Looking for a clean cylinder is usually definitive on slow seeps that are not easily seen but on a fresh hg job those cylinders would have been steam cleaned from the first fail.
    #15 rjparker, Oct 25, 2024
