identify part
Discussion in 'Gen 2 Prius Main Forum' started by bugmenot, Dec 29, 2006.
  1. bugmenot
    bugmenot New Member
    93
    I found this part in the car and hope someone knows what it is.
  2. jamarimutt
    jamarimutt New Member
    985
    It's a seal that's supposed to be installed somewhere under the car. I found two of those in a plastic bag in the lower glove box.
  3. Ghostrider
    Ghostrider New Member
    121
    <div class='quotetop'>QUOTE(jamarimutt @ Dec 29 2006, 08:05 PM) [snapback]368442[/snapback]</div>
    Search for the new owners checklist. It's a plug that goes into the fram back near the rear door. The checklist has a better description of where.
  4. bugmenot
    bugmenot New Member
    93
    I found the checklist and there's an image of a similar plug but it's rubber and not plastic and it appears more circular than oval, but it does go under the car.
  5. member
    member New Member
    197
    <div class='quotetop'>QUOTE(bugmenot @ Dec 29 2006, 06:12 PM) [snapback]368419[/snapback]</div>
    Looks *exactly* like the solid plastic "grommet" that our child seats' belts use
    between belt and seat.
  6. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(bugmenot @ Dec 29 2006, 10:57 PM) [snapback]368479[/snapback]</div>
    No, it's definitely not that rubber seal.
    Now as to what it is ... I suppose if you can't find a hole anywhere that it would fit, then I wouldn't worry about it.
    <div class='quotetop'>QUOTE(Display Name @ Dec 29 2006, 10:58 PM) [snapback]368480[/snapback]</div>
    It does look like some sort of a piece of trim for a seat belt, doesn't it?
  7. bugmenot
    bugmenot New Member
    93
    I'm not sure if it's for the seat belt since my interior is gray and I don't see any similar black trim parts.
    It's just one piece and it looks like it's been pryed a bit.
  8. cbs4
    cbs4 Member
    105
    I can't tell from the picture how large the part is.
    If you happen to have 1,200 thread count sheets that you photographed that item on, then that part could be quite small, which would make a difference in what hole to hunt for.
    On the other hand, if you happened to take that picture on a bed at Motel 6, then... well, you get the idea. It would help to have a sense of scale.
    What are the dimensions?
  9. bugmenot
    bugmenot New Member
    93
    Off the top of my head it's maybe 2 inches in length and maybe an inch in depth.
  10. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    See Page 19 of the attached Pre-Delivery checklist where it says - "Install Body Plugs"
  11. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(Tempus @ Dec 30 2006, 09:12 AM) [snapback]368567[/snapback]</div>
    Yes, except this is not one of those.
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Maybe it's not a Prius part?
  13. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    I feel like I am part of Ask This Old Prius.
    Is what I see on the surface instructional pictorial markings? Might be a clue to its purpose.
  14. Prius The First
    Prius The First New Member
    141
    It is probably a part from another car that the robots that build these cars were throwing at each other because they were bored.
  15. bugmenot
    bugmenot New Member
    93
  16. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(bugmenot @ Dec 30 2006, 06:18 PM) [snapback]368782[/snapback]</div>
    That pretty much settles the size issue. It is not the plug. Where did you find it? In the bad old days when I worked on the assembly line for FoMoCo if we dropped something into the car during assembly it did not always get picked up. We would reach in the bin and grab another. Speed was key. I will go back out to look again! I love a mystery!
  17. bugmenot
    bugmenot New Member
    93
    It was just there in the door holder.
  18. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(bugmenot @ Dec 30 2006, 11:56 PM) [snapback]368821[/snapback]</div>
    Somebody found it and stuck it there. Possibly could have been done at the shop and forgotten, who knows. By door holder I'm assuming you're referring to the interior door handle.
    Have you interviewed the passengers (assuming it was adjacent to a passenger seat)? Family members like to stick things in the door handle.
  19. bugmenot
    bugmenot New Member
    93
    No one knows what the part is.
  20. Tideland Prius
    16,122
    wow... we still haven't solved this?
