Identify this Modification
Discussion in 'Gen 2 Prius Main Forum' started by mdrudeen, Aug 26, 2007.
  1. mdrudeen
    mdrudeen New Member
    Long story short, I bought a very slightly used (170 miles) 2007 touring PKG six from a dealer. It came equipped with a strange button that he could not identify. He said he would e-mail me the accessory list for the car but he has not yet. So what do you think Priuschat folks, can anyone name the function of this device?
    The light blinks blue when the power is off but turns off when the power is on. Both buttons appear to be pressable but have no effect on the car
    http://picasaweb.google.com/mdrudeen/Prius...175641589045842 for a bigger view
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    check to see if they enable full access to the bluetooth phone (top button) and NAV (bottom button) when the car is in motion. Just guesses based upon the telephone look of the top button.
    That isn't any common button/mod I've ever seen, but those two mods (disruption of the speed sensor wires to allow full access to BT and NAV) are common mods.
  3. Tideland Prius
    16,445
    Yeah I haven't seen it before but it could be an aftermarket BT set?
  4. echase
    echase New Member
    227
    Be careful, I think the bottom one activates the ejection seat.
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    The top button is one of the space ships from Space Invaders and the bottom one is clearly the international symbol for "D-Fence!" albeit sideways.
    Rorschach, out!
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Blue tooth
  7. hill
    8,640
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Aug 27 2007, 09:24 AM) [snapback]502675[/snapback]</div>
    Space invaders, pong, tail gunner, asteroids, let's not be giving away our ages now.
  8. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    My guess: it's the ET mod. :D
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
  10. echase
    echase New Member
    227
    <div class='quotetop'>QUOTE(zenMachine @ Aug 27 2007, 10:45 AM) [snapback]502699[/snapback]</div>
    ROFL - Brilliant
  11. koa
    koa Active Member
    980
    45
    Hawaii
    Maybe it's an additional alarm that will call you to let you know the car is being tampered with.
  12. iaowings
    iaowings New Member
    450
    if set up right its the button the thief presses to ask u "yo now that im in your car how the hell do i start it man?"
  13. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    Efusco had a great suggestion, but one question is... Does that Prius have Nav and Bluetooth? If it does (package 5 or 6 for 2007 model) then I would say it's very possible that could be a Nav and Bluetooth speed sensor override. But, the fact that it lights up when the power is off and the light is off when the power is on leads me to think it may be related to some kind of aftermarket alarm system. The best way to find out what those buttons are for is to take some of the dash panels off to get behind those buttons and find out where the wires go to (crawl around under the dash with a flashlight). They must be splice into something or they must be plugged into a box somewhere in the car, just find out where they go and we should be able to figure it out from there.
  14. Barcelona Red Lass
    Barcelona Red Lass Sips gas like fine wine!
    227
    Sunny So.Cal!
    It's obviously the double secret button developed by the Coalition of the Willing that, when pushed, blows up France, only France, and ALL of France.
  15. mdrudeen
    mdrudeen New Member
    <div class='quotetop'>QUOTE(lass @ Aug 28 2007, 07:01 PM) [snapback]503507[/snapback]</div>
    Ooops , sorry France I will miss your pomme frites
    I am going to the dealer today for a separate isssue so I will press him on identification and report back if I find anything. The wife was less than enthused with the remove some dashboard panels option
  16. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(ilusnforc @ Aug 28 2007, 05:57 PM) [snapback]503450[/snapback]</div>
    If you have trouble tracing the wires (which can be a challenge behind the dash), you could remove the switch panel and apply 120V to the connectors. Then just watch to see where the puff of smoke comes from. :D
  17. TonyPSchaefer
    14,816
    2,499
    66
    <div class='quotetop'>QUOTE(GeoDosch @ Aug 29 2007, 08:44 AM) [snapback]503716[/snapback]</div>
    That's so brilliant is HAS to work!
  18. Norm611
    Norm611 Junior Member
    45
    Western New York
    The lower button softens the ride when crossing railroad tracks. ;)
  19. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    It really isn't difficult to remove a few panels from the dash. First off, you can start by pulling of the left vent piece, just push down on the top edge and pull it straight back toward you and it should pop off. Once the vent panel is off you can just about reach your fingers in behind the 3 blanks where your mystery buttons are and pop those blanks out so you can see the wires behind it. I guess you really wouldn't need to do that if you can get under the dash with a flashlight. Once you get the left vent panel off I think there are just two phillips head screws holding the lower panel of the dash on just below the steering wheel, that should be easy to get off then you can really take a look around. It's really not difficult, look for PDF files with step by step dash removal instructions for the EV button install and you should be able to get just a few little panels out of your way to see what's back there, I don't literally mean to take the entire dash out of the car.
  20. Barcelona Red Lass
    227
    Sunny So.Cal!
    <div class='quotetop'>QUOTE(ilusnforc @ Aug 29 2007, 02:42 PM) [snapback]503977[/snapback]</div>
    For those of us who are less hands-on, that sounds like a REALLY scary option. I mean, what happens if I break something?? That's also why I'd never try the "apply 120 volts and wait for the puff of smoke" option either!
