"Identify this part I've circled" challenge
Discussion in 'Gen 4 Prius Technical Discussion' started by Bri89, Mar 8, 2024.
  1. Bri89
    Bri89 New Member
    My car got damaged by rodents. I have a good mechanic but would like to know more going in before I show up.
    The ONLY damage is to the circled part in this stock photo which no longer exists in my car and two little sad wires are left poking out of the big bundle.
    What is this part called and what did it do? My error codes are all nonspecific and every one seems to be screaming about the voltage.
  2. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    I'm looking at the one on my car which is similar. It is on the 12V battery negative terminal bus and appears to be some sort of current or temperature sensor. There is a two conductor wire leading away, your remaining two wires, that plug into a sensor of some sort on the side of the battery negative terminal clamp. There also might be something in that flat black plastic piece on top, which I don't feel like trying to disassemble at the moment.
    #2 AzWxGuy, Mar 9, 2024
  3. ChapmanF
    15,697
    the battery state sensor assembly
    AzWxGuy likes this.
  4. Mr.Vanvandenburg
    1,066
    371
    2020 Prius Prime
    And it isn’t cheap.
  5. vvillovv
    vvillovv Senior Member
    3,689
    1,302
    NY
    I'm gonna be more careful with that next time I remove it from the - terminal
    :p:eek::oops:o_O
    Here's hopin the car scanner update has the correct PID of it this time.
    #5 vvillovv, Mar 9, 2024
