Identify this wire terminal..
Discussion in 'Gen 3 Prius Audio and Electronics' started by Peter Chong, Jul 29, 2021.
  1. Peter Chong
    Peter Chong New Member
    Houston
    Thought this forum would be more helpful than technical discussion
  2. ASRDogman
    ASRDogman Senior Member
    7,610
    3,916
    Atually, it's a terminal, not a wire. Many manufacturers use it.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,435
    Taylors, SC
    Looks like a "female" pin terminal socket. It's an old style crimp that folds over the insulation and the wire. I have a crimper that does that. It originated with the telephone industry in the 1920's.
  4. ChapmanF
    18,250
    This post is an example of how you look up the terminal part number in the Electrical Wiring Diagram.
    This other post is an example of the earlier steps, navigating the wiring diagram down to the right system and connector.
    Peter Chong likes this.
  5. Peter Chong
    Houston
    Thanks guys for all the recommendations. Eventually after contacting a houston automotive pigtail company here who said they carried it, I just wen to a junkyard to pick it up. Then it came with the rear axle beam assembly that I purchased too. So ended up not needing to do my original plan.
