Identify this
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jimlarge, Oct 11, 2023.
  1. Jimlarge
    Jimlarge Junior Member
    27
    MN
    I I'm trying to get my 2007 Prius back on the road after a deer hit.
    I don't know what this piece does or is or if I should replace it any help is very much appreciated.
    Thanks!
  2. ChapmanF
    15,533
    Goes beep when you get out with the car on.
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    So that's where the transducer is located, so if you cut it the alarm doesn't sound, or is that some other output device?
  4. dolj
    dolj Senior Member
    7,636
    3,853
    Wellington, New Zealand
    I don't think it has anything to do with the alarm. It's a relatively quiet beeper.
    SFO likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,444
    1,496
    NJ-USA
    The alarm system has its own horn that's mounted behind the engine. It doesn't use the regular horn.
    That piezo widget goes beep-beep when you hit the unlock button on the key fob.
    SFO likes this.
  6. ChapmanF
    15,533
    That was some of the first nonsense I turned off with Techstream when I first brought my car home.
    But even with that turned off, it still goes beep-beep-beep if I get out and close the door with the car on. (In a Gen 3, anyway.)
