Idle Air Control Valve IAC
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by simonman, Feb 18, 2019.
  1. simonman
    simonman Junior Member
    Grand Rapids, Michigan
    I have a 2014 Prius C. I cannot find whether or not there is an idle air control valve on it.
    iPhone ?
  2. ChapmanF
    15,450
    I'm not aware of any Prius model having or needing an Idle Air Control valve. It's got a full-fledged electronically controlled throttle. Will it disappoint you not to have an IAC?
  3. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    It doesn’t have one. It’s all controlled by the ECU via the electronic throttle body.
  4. simonman
    No disappointment. Just checking over what all may need to be cleaned out when cleaning the throttle body.
  5. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Be careful cleaning the TB. Don’t force it or push it open in any way. I’ve read a few accounts of people damaging it while trying to clean it too thoroughly. When I did mine I just used q tips soaked in carb cleaner and cleaned around the edges of the throttle plate.
    Bohemian Grove and simonman like this.
