Idle/low rpm vibration( big time)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AKoffgrid, Jul 28, 2023.
  1. AKoffgrid
    AKoffgrid New Member
    Alaska interior
    Gen 2 2007
    260k miles
    At present no codes.
    Previous repairs: coolant switch and pump.
    My prius recently started having an intense vibration at lower rpms.It vibrates the whole car almost like a huge subwooferwould. Under heavy acceleration it is gone. When petrol engine is off and regen in process it is also not present.
    I found and read LOTS of threads for gen 3 , but does not look like gen 2 has same EGR system, so my "next step" is unknown now.
    If air filter is removed for test. . . Issue still present. No visible dents or restrictions in exhaust system.
    Thank you for content many of you already provided, and thank you in advance for any assistance.
  2. PriusCamper
    PriusCamper Senior Member
    11,134
    4,534
    Pacific Northwest, USA
    Sometimes this happens when a cat shield isn't properly installed. Is that possible?
    And this is different from the occasional shuddering of the Atkinson engine when cold on shut down at a stop light?
    AKoffgrid likes this.
  3. AKoffgrid
    Alaska interior
    Intense full car vibration. Not a rattle. Like i wear my shooting hearing protection when I drive. P0420 showing now, have a thought on clogged cat?
  4. PriusCamper
    11,134
    4,534
    Clogged cat usually causes the flange gasket between exhaust header and cat to fail. It will make the engine compartment smell like a 1970's car and it will run way louder but that's not the source of full car vibration, which is usually some kind of engine failure.
    How's your MPG? Still got normal engine power?
  5. AKoffgrid
    Alaska interior
    Mpg on highway is normal for my car, 43 mpg. Around town is terrible, but running the AC at idle a lot, so not a fair evaluation, but it is 35mpg avg around town ( normally around 38 this time of year running ac)
    I have a 2009 donor car if it helps with troubleshooting.
    Side note, do you have a thread on your experience with your lithium conversion?and expierience since then?
    Also thank you for your interest and help thus far!
  6. AKoffgrid
    Alaska interior
    Apologies, forgot to answer second part.
    Power is fine, zero noticable loss.
  7. PriusCamper
    11,134
    4,534
    Here's the first thread I did on that subject nearly 3 years ago: Dr. Prius Packs Less Than A Year Away? | PriusChat
  8. AKoffgrid
    Alaska interior
    Updates.
    Vibration stopped, fluttery noise now at high rpm. ( lasted week )
    Exhaust smell, ( assuming gasket pushed out, resolved possible back pressure issue)
    Now mpg around 40 ( drive batteries not doi g so well)
    Amazon high flow cat been en route /on order ( some times things take a long time to get to a village in Alaska)
    Plan to ride this problem and thread out in case it helps anyone in the future.
  9. AKoffgrid
    Alaska interior
    High flow Cat installed today. . . In the second snow of the season. . .
    Overall went well.
    Dohnut gasket was damaged and pushed out with some frayed bits.
    Cat was clogged 50% or more on front end.
    Pre install: stinky cab at low speeds or idle, 33ish mpg, ugly flappy ( exhaust leak. Oise) at heavy acceleration.
    Post install: 40.7 mpg :0D, no more in cab stink ( new pipe heating up smelled first 5 miles) 20230927_194714.jpg old gasket
    20230927_194753.jpg old cat front end
    20230927_194904.jpg new cat front end
    20230927_205718.jpg happier mpg and smell
    So unless someone has a question this thread is done.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    3,501
    1,599
    NJ-USA
    So what is that crap that clogged the cat? Where did it come from? Will this happen again?
    Usually I see carbon/oil residue buildup on the catalyst face, not white-ish granular stuff. It doesn't look like the catalyst substrate has broken up at all.
  11. AKoffgrid
    Alaska interior
    Its from burning oil, it will happen again.
    It is not white ( camera flash) not much natural light 11pm in Alaska interior.
    Granular items are likely build up knocked loose in my sawsall vibration attack ;)
    About 160 miles in so far, happy as a clam.
  12. bisco
    49,592
    are you selling the old cat? if oem they're worth some money
