If anyone interested in changing the upfront O2 in the exhaust manifold this tool is necessary.
Discussion in 'Gen 2 Prius Audio and Electronics' started by audiodave, Nov 22, 2018.
  1. audiodave
    audiodave Active Member
    798
    269
    US
  2. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Your link doesn't seem to work but you must mean one of these.
  3. Mendel Leisk
    41,143
    Link's working for me, looks like this:
    Slim wall is important, clearance is very tight?
    There's mention of SST's in this, maybe the numbers will help in a search.
  4. LEVE
    LEVE Member
    191
    97
    On the Willapa
    I have both of those sockets and use them on O2 sensors rusted into manifolds for the last 25 years. The second one, looking like a deep socket is OK for reinstalling an O2, sensor, but I've had this socket spread as I'd attempt to wrench it out. The first socket referenced is much stronger with thicker walls. It's my Go-To socket if I have to remove a sensor. It's never failed me.
    NortTexSalv04Prius likes this.
  5. audiodave
    798
    269
    US
    It can't be thick to fit the shielded sensor on the Prius.
  6. SdzDesigns
    SdzDesigns New Member
    Parma
    i only had the deeper socket last week when i did mine. I had to cut and move the shield out of my way (big pita). After that it was no big deal.
  7. Thurmand
    Thurmand New Member
    Tallahassee FL
    yeah, you should be using an oxygen sensor socket with any oxygen sensor to keep from damaging the wire or plug
