If it isnt the bearing... what is it???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Casktcrw, Sep 28, 2022.
  1. Casktcrw
    Casktcrw New Member
    Providence
    The grinding type noise came on slowly and got louder over time. It got louder when i bear right, and disappeared when i bear left. I had no doubt it was the left side front wheel bearing, until mechanic installed a new skf hub and it made NO difference in the soundz Personally i think he overtigtened it, but that's whatever.
    What else could it be?
  2. Tombukt2
    Tombukt2 Senior Member
    12,213
    2,153
    Durham NC
    It's a sealed bearing assembly so over tightening it unless it's severely overtightened. Shouldn't really hurt too much is also a pretty big nut. I can't imagine what happens if you jack the front wheels off the ground and let the tires rotate or drive the car with the front end up in the air does it still make the noise?. I mean some of this stuff can be pretty difficult to diagnose but maybe you can record it I don't know both my Gen 2's with 300 plus thousand they creek and groan when the suspension rises and lowers acceleration and deceleration. But that's all struts and maybe end links I'm trying to hold out to see if the wheel bearings would go bad because I like to do wheel bearing struts and end links all at the same time so there's no reason to take the front end apart again pretty much you can also put inner and outer tie rod ends on the rack or replace the rack at that time if it's deemed necessary and that pretty much completes your whole front end if I can do that at one time it's a great thing
  3. Mendel Leisk
    40,583
    CV joints are noisy when turning one direction, but not the other. More of a pulsation noise though.
  4. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    A different wheel bearing. They are ventriloquists. Many stories of replacing the wrong one.
    Sometimes somebody has to use a set of chassis ears (name of tool) to work out which one it really is.
    rjparker and mr_guy_mann like this.
  5. Tombukt2
    12,213
    2,153
    Durham NC
    Usually I do the axle as set always. I've never replaced just one. Even cars that I work on I always convinced the customer friend to just do them in pairs it's silly not to going to have the car apart jacked up anyway might as well hit the two front or the two rear
    rjparker likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    I have had "no doubt" about which bearing was noisy too many times over the years. I gave up trying to ID a bad bearing from just listening in the driver's seat.
    I use Chassis Ears (remote microphone system) during a road test, spin the wheels by hand on a lift, "drive" the car on a lift & listen for noise or feel for vibration, or have a helper stick a head out the window during a road test.
  7. ChapmanF
    17,345
    Another vote for Chassis Ears. I had a bearing where none of the familiar tricks could identify the bad one (didn't run measurably hot, didn't feel loose, didn't spin roughly with the corner jacked up and the weight off, noise didn't change in the predicted way when cornering), but a short drive with Chassis Ears identified it in seconds.
  8. Casktcrw
    Casktcrw New Member
    Providence
    I get thinking you hear it on one side and being wrong… But the noise stops entirely when I turn left no matter how fast… When the weight shift onto the right bearing. I cannot imagine it being the right bearing.
  9. Casktcrw
    Casktcrw New Member
    Providence
    I'm identifying it by which way I turn not by what it sounds like. When I turn left, no matter how fast the sound is gone. At that moment the car's weight is leaning in the right wheels.
  10. Casktcrw
    Casktcrw New Member
    Providence
    It was the front right bearing. Very strange.
  11. Casktcrw
    Casktcrw New Member
    Providence
    I don't know whether to laugh or cry I leave the shop get on the highway and now it's got a vibration at 70 did not have this morning. I had a moog in my trunk jic the skf was bad. But if it turned out to be the other side not a bad skf I was going to return and buy another SKF but of course the mechanic didn't even say anything just took it and installed it. I know moog has lesser reputation i hope its not junk
  12. Casktcrw
    Casktcrw New Member
    Providence
    Do i need an alignment after removing the spindles?
  13. ChapmanF
    17,345
    As recounted in #7, the common idea that you can identify the failing bearing according to how it sounds when you turn corners is anything but dependable. It can give you the complete wrong idea.
  14. Casktcrw
    Casktcrw New Member
    Providence
    Now the effin thing has a shake on the highway
  15. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    Hello Ocean-State person, and fellow New Englander!
    I can save you a lot of money and time.
    Instead of buying more similar bearings, just send the money directly to me - I take PayPal! ;-)
    Fwiw, buying wheel bearings, and many other automotive parts, from ANYWHERE other than directly from a dealership, is like playing Russian Roulette with 90% of the chambers filled.
    Code:
    https://www.autoserviceworld.com/carsmagazine/counterfeit-bearings-seized-at-toronto-airport/
    https://www.worldtrademarkreview.com/global-guide/anti-counterfeiting-and-online-brand-enforcement/2019/article/counterfeit-automotive-parts-increasingly-putting-consumer-safety-risk
    https://www.youtube.com/watch?v=FVA4RYql9KU
    Toyota Counterfeit parts EXPOSED!
    Feb 6, 2021
    The Car Care Nut
    https://www.youtube.com/watch?v=OpDJNDb6b9A
    Don't Get Burned Buying Counterfeit Ford Motorcraft Parts!
    Feb 14, 2020
    FordTechMakuloco
    I suggest that people go, in person, to their local dealership.
    Fwiw, your local parts store isn't any better.
    First, the knowingly sell cheap garbage that has a high return rate.
    Second, "the company gets 'taken/fooled' by 'unknowingly' buying counterfeit parts". LMAO!
    The States and Federal government has stopped suing the big automotive parts stores for selling counterfeit parts, so that every court in the world would be backlogged for 100 years with those cases. Iirc, they stopped the constant law suits around the 90's, when the States and Federal Government decided there were better usages to spend their limited resources.
    Consider how much you paid in parts and labor already (and travel, gas, lost time, etc). Verses, getting a part directly from a dealer, and having an OEM part, that will very easily last another 10+years.
    Your money, your choice.
    Good Luck!
    #15 prius16, Sep 29, 2022
  16. ttou68
    ttou68 Active Member
    351
    209
    You're more than likely need a wheel alignment check, if spindle was detached from strut to remove wheel bearing...
  17. rjparker
    rjparker Tu Humilde Sirviente
    9,596
    5,893
    Texas Hill Country
    Not really. Smart people are continuous learners. Assumptions get you every time. Or at least some of the time. Bet it won't happen to you again.
  18. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    I normally order from RockAuto, RockAuto drop ships, they do not stock most parts. As in, they send order to Timkin/SKF/NSK etc. and those companies do the shipping.
    If I know the OEM supplier that's what I order from RockAuto.
    #18 alftoy, Sep 29, 2022
    Prius Rising likes this.
  19. prius16
    462
    243
    New England
    2022 Prius Prime
    That's incorrect, Goggle.
    Iirc, RockAuto has never stocked any parts, nor has had any warehouses.
  20. alftoy
    1,132
    514
    Where did I say RA and warehouse? What is drop ship? Do not stock?
    #20 alftoy, Sep 29, 2022
