If timing chain stretches, doesn’t the chain tensioner expand?
Discussion in 'Gen 3 Prius Technical Discussion' started by jtnb89, Mar 17, 2023.
  1. jtnb89
    jtnb89 New Member
    I hope this is not a dumb question, but I’m going to ask anyway…
    Recently my timing chain has gotten loose… engine is making knocking sounds. So I’m ordered a new timing kit… hopefully this fixes my problem… but my question is, is the chain really did stretch a bit and get loose, why didn’t the hydraulic chain tensioner expand and make the chain tighter?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,125
    2,182
    Taylors, SC
    The timing chain does not actually "stretch" much at all. The metal components that makes up the chain is not vert ductile and will not actually deform much. It it the lack of proper lubrication and/or abrasive particles or detritus that wears the space between the components that causes the timing chain to lengthen.
    The tensioner applies pressure to maintain a degree of pressure to keep the chain in contact with the timing gears but does not reposition the space between the gears. So, the only way to resolve your issue is to replace all of the timing components including the chan, the gears and the guides.
    More frequent oil and filter changes would have delayed the onset of your particular situation.
  3. jtnb89
    jtnb89 New Member
    Thank you! That makes perfect sense!
    48,979
    how many miles on her?
  5. Tombukt2
    Tombukt2 Senior Member
    8,111
    1,404
    Durham NC
    Intergeneration 3 I wouldn't be banking on this. How many miles are on this vehicle let's start somewhere that we need to start In most Toyota's that I've owned over the last 47 years The timing components generally outlasted the car very few Toyota engines I've had to replace timing components on very few and I'm talking about things seriously out of spec making noises and ticks and all of that.
  6. bisco
    48,979
    i wonder if the knocking sounds might be egr or head gasket
    Tombukt2 likes this.
  7. Tombukt2
    8,111
    1,404
    Durham NC
    Bingo
  8. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Wear ("stretch") lengthening of the chain with mileage gradually throws off the angular relationship between crank and cam sprockets. Up to a point, the tensioner's job is to take up the resulting increase in slack on the slack side of the chain. How loose is your chain?
  9. Mendel Leisk
    38,247
  10. rjparker
    rjparker Tu Humilde Sirviente
    7,600
    4,457
    Texas Hill Country
    This is a case of dual threads on the same subject. In his other thread he shows the chain which does appear loose. Op should avoid doing this so continuity is maintained. Probably a good idea to change the timing related parts. The tensioner could be the issue as well as chain wear.
  11. jtnb89
    jtnb89 New Member
    I’m sorry about this. I guess things took a bit of a turn for me, thus the reasoning for a new topic. I do apologize. But once the timing kit comes in and if it fixed my issue I will update!
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    A good moderator would have fixed that. :)
    jtnb89 likes this.
  13. ChapmanF
    15,099
    A good member has the option of clicking Report and considerately asking the moderator to do that.
  14. Mendel Leisk
    38,247
    Once two threads get going it becomes nigh impossible to merge, coherently?
  15. rjparker
    7,600
    4,457
    Texas Hill Country
    The moderator has to be coherent and make necessary edits.
    #15 rjparker, Mar 19, 2023
  16. ChapmanF
    15,099
    It's like the old gag about the two hikers and the bear.
    The merged thread only needs to achieve more coherence than the original hodge-podge of separate ones.
    Foxglove and Mendel Leisk like this.
