If you think you have heard everything....cosmic rays?
Discussion in 'Fred's House of Pancakes' started by malorn, Mar 16, 2010.
  1. malorn
    malorn Senior Member
    4,281
    59
    "Somewhere in Flyover Country"
    Are cosmic rays really causing Toyota's woes? | freep.com | Detroit Free Press
    WASHINGTON -- It may sound far-fetched, but federal regulators are studying whether sudden acceleration in Toyotas is linked to cosmic rays.
    Radiation from space long has affected airplanes and spacecraft, and is known for triggering errors in computer systems, but has received scant attention in the auto industry.
    I had this emailed to me late last night. I am certainly not very scientific but it would make quite the story..
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    The Robinson family had to put with "Cosmic Storms" all the time....The Chariot never suddenly accelerated!
    Well OK, it was a '65 Thiokol "Spryte" Snow-cat, not a Toyota!!!
    Lots of Cosmic Storms however.....
  3. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Cosmic rays, GIC, EMI, Directed Energy Weapons, all are fascinating
    Especially their impact on sensitive electronics
    Most hardened systems use special radiation hardened microprocessors, which must continue working up to 100 K Rads
    As a point of comparison, 1,000 Rads is a fatal exposure limit for almost 100% of humans. 100,000 Rads is quite a bit higher than that
  4. Politburo
    Politburo Active Member
    971
    208
    Note that the article is based largely on the testimony of someone in a position very similar to Sean Kane.. except this guy runs an EMI testing firm.
  5. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    So when will the Prius Shop start carrying a honkin' big tinfoil hat to place over the entire car? :tinfoil3:
  6. moxiequz
    moxiequz Weirdo Social Outcast
    2,781
    Bay Area, CA
    Alternatively you can just go down to Costco (or whatever wholesaler you're closest to) and get enough foil to cover your Prius yourself. It's a good weekend project.
    Don't forget to leave some uncovered areas on the windows - particularly that big front one. Boy, did I learn that lesson the hard way!
  7. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    We used to have some electrical problems in the north of Alaska when I was in the service...
    Although, I think if it is gonna affect one car down here, it should affect many more to be evidence of other forces at work other than the car malfunctioning, or the operator error/intent.
  8. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I propose using a bunch of foil condom wrappers to block the EMI. family planning is good for the environment and so is recycling.
  9. jayman
    13,439
    640
    Winnipeg Manitoba
    Even minor solar storms can cause major GIC (Geomagnetically Induced Current) in the northern regions of Alaska and Canada
  10. amm0bob
    7,730
    2,547
    I'm just saying... I think more than one car would be impacted if that were the case...
  11. jayman
    13,439
    640
    Winnipeg Manitoba
    Precisely
