ignition plus on jbl system
Discussion in 'Gen 2 Prius Audio and Electronics' started by tschmidt84, Aug 12, 2004.
  1. tschmidt84
    tschmidt84 New Member
    Germany
    hi! where can I find ignition plus on the jbl amp system? is there such a thing in this car? thx! thomas :)
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Not sure what you mean. Are you looking for the "remote" line for the amp for turnon?
  3. tschmidt84
    Germany
    uhm, I don't know how it's called in english, but basically the ignition plus is 0 volts when the engine is not running and 12 volts when the engine is started or the key is turned into the IGN position. but since there is no regular ignition in the prius, I don't know where to find it... :) thx for any help...!
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    If you're looking for the wire that is powered on with Ignition on there is a light blue wire in the bundle behind the radio stack that's the one you're looking for. Of course, please test to be sure, but that's where it was when I installed my XM Commander.
  5. djc
    djc Junior Member
    24
    Oak Park, IL
    I don't know the color codes on the amplifier inputs, but I do know the colors on the connections to the head unit:
    POWER
    * memory........blue
    * ignition..........grey
    * ground..........brown
    * illumination...green
    * dimmer.........white / black
    SPEAKERS
    * Right +...........red
    * Right -............green
    * Left +..............white
    * Left -...............black
    These were determined by an owner using an oscilloscope to engineer how to attach an MP3 player through the amplifier. I plan on following in his steps this weekend.
    --Dan.
  6. tschmidt84
    Germany
    efusco: yes, that's the wire I'm looking for! thx a lot! :)
    but light blue or grey? ;) and where can I find this on the jbl amp?
    btw, it's so great to have an internet site like this one just for your car! :)
  7. efusco
    19,891
    1,192
    Nixa, MO
    The one we tapped was definately light blue...I would not call it gray. Now, whether there is another directly at the amp that is gray and does the same thing I can't say for sure one way or the other.
    I know there's a photo, maybe on this site, somewhere that shows that exact wire....take a look through the photos sections and see if you can find it.
  8. brettray
    brettray New Member
    28
    Livermore, CA
    On the amp itself (under the passenger seat) there is also a gray wire which is switched power. It is in the smaller connector (with the higher gauge wire) and off to one side (kind of by itself). Good luck in finding it!
  9. tschmidt84
    Germany
    thx! :) just what I needed...everything worked out fine! after-market BT car kit up and running (center speaker)!
  10. HTMLSpinnr
    5,341
    920
    251
