IIHS safety ratings for Prius Primes
Discussion in 'Prime Main Forum (2017-2022)' started by Jeff Hicks, Oct 18, 2019.
  1. Jeff Hicks
    Jeff Hicks Junior Member
    37
    24
    Huntsville, AL
    2020 Prius Prime
    #1 Jeff Hicks, Oct 18, 2019
    schja01 likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Looks like all the crash tests were either 2016 or 2018 Prius, unless I missed something. I guess they didn't want to destroy a Prime. I can't blame them. :)
  3. Jeff Hicks
    37
    24
    Huntsville, AL
    2020 Prius Prime
    In the linked video at around 2 minutes he says that IIHS considers the Prime structurally the same. I guess the additional battery weight doesn’t effect the results? I wonder if the Primes headlights would score higher though?
    #3 Jeff Hicks, Oct 18, 2019
    jerrymildred likes this.
  4. jerrymildred
    11,508
    14,109
    Tampa, FL
    I sure hope so. They're amazing!
  5. fuzzy1
    10,165
    Under the Headlights section, compare the Technical measurements for this test figures for the Prime against both headlight variants of the regular Prius.
    The Prime's measurements are different than both regular Prius version measurements, so it appears that they didn't just copy over headlight numbers from one model to the other.
  6. PianoBench
    PianoBench Member
    145
    91
    San Francisco
    Maybe the simple answer is that when they tested the 2016 Toyota Prius in the crash tests, the Toyota engineers tested it for the worst case scenario. IE they added the additional weight for their future planned vehicles. 3000 LB to 3500 LB is not that much different. They can add or remove ballast as required.
