Illumination for Center Dash Storage Bin
Discussion in 'Gen 2 Prius Accessories & Modifications' started by wpavalko, Feb 4, 2006.
  1. wpavalko
    wpavalko New Member
    All:
    I'm trying to see if anyone else is bothered by the lack of illumination for the center dash storage bin (under the radio). I just got my '06 and although I don't have a use for that bin yet, why would I use it if I can't see inside at night?
    I came up with a solution that works pretty well. Anyone interested in buying one if I made some more? Production units would be much cleaner in appearance and I would shield LED. Only comes on when you open the door to the bin.
    Note that it's attached with some double-sided tape, so it doesn't damage the dash. The screws are my cheap way of holding the battery to the PCB.
    --WJP
  2. Tideland Prius
    16,159
    cool! I'd rather have one for the upper glovebox though.
  3. dreichla
    dreichla New Member
    2,230
    Connecticut
    Sounds interesting.
    Someone should figure out a way to turn OFF the glove box light when it's closed.
  4. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    I got one of those sylvania dot it lights and placed it in the mp3 player slot, but it has to be switched on manually
  5. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    btw, is the glove box light standard or depends on the package? mine's #2
  6. Tideland Prius
    16,159
    Yep. It's the amber/orange light.
  7. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    well, I sure don't have that activated... is it an LED or regular bulb? saw a hole that looks like it could contain an LED... i'm currently using one of those magnetic proximity LEDs and it's white
  8. Tideland Prius
    16,159
    Glovebox right? The lower one?
    It has an orange/amber LED. Turn on your side markers (or headlights) to activate it.
  9. hefaust
    hefaust New Member
    32
    Indianapolis, IN
    I observed the same thing. Fumbling for my trip/odo button at night often resulted in KP/H on my speedo.
    To solve the problem, I installed a mirror that's normally found as an option for the Scion TC. It not only has homelink and is self-dimming, but has a really cool LED that casts an unobtrusive, almost restaurant-like lighting ambiance over the center dash, console, and doors. You can even choose lighting colors - amber, blue, or white. Or, you can have the lighting change color intermittently.
    Erick Faust
    Asst. Service Manager,
    O'Brien Toyota/Scion
    Indianapolis, IN
    2008 Barcelona Red
    1870 miles
    Avg FE - 49.2mpg (thanks to foaming)
  10. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Welcome to PriusChat Eric.
    Sounds like a great mod. How would you rate the difficulty of the install for the average owner? Cost range?
  11. Tideland Prius
    16,159
    lol. I forgot about that option (well accessory) for the Scion range!
    Yes that is quite cool and now that you've mentioned it, quite useful too! But it'll work if you don't have the auto-dimming mirror in the first place, otherwise it'll be an expensive replacement!
  12. hefaust
    hefaust New Member
    32
    Indianapolis, IN
    The install was quite easy. I'm a service manager for a Toyota dealership and had my head Prius tech install it. It only took him 45 minutes to complete and the results are phenomenal. I love driving at night with that low amber ambience bathing my center dash/console/doors. As soon as I get my Coastal Ipod MFD interface, I'll not be fumbling for my Ipod in order to groove to Steely Dan whilst driving with the really cool lighting.
    Installation should be simple. All you need is one constant hot wire, one ground, and one accessory wire - all can be accessed via the fuse block. The ground and accessory hot can be tapped into the map lights or vanaity lights. If you have package #3 or above, you'll have all the wires at the mirror location.
    Erick
  13. patsparks
    10,664
    567
    Adelaide South Australia
    Personally I'd rather see what is happening outside my car when I'm driving.
  14. LYLUVLY
    LYLUVLY New Member
    150
    Huntington Beach, Ca
    I want the same as you AND make them brighter !!
  15. kathyb
    kathyb New Member
    53
    Brooklyn, N.Y.
    It drove me crazy the other night when I was leaving the car and noticed some amber light coming from the crack of the bottom glove box.
    It stays on all the time....does anyone know why and a way to have it only come on when the glove box is opened?
  16. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    that's odd... I had tried turning on the lights previously before posting up and it never worked; I've never noticed it on while driving to work in the early morning, but it was clearly visible when I went to try again just now
  17. Tideland Prius
    16,159
    heh. ok well at least it works.
  18. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    Erick: I have a 2004 #7 option package. Is the wiring already in place for the addition of the illuminated mirror you installed? Is this something my dealer can do? What would it cost, approximately (since different dealers vary)? How do you get changing colors?
    Your mod sounds great. I don't like the cavelike interior at night and have been playing with different aux lighting options.
    Thanks,
    Bob
  19. Tideland Prius
    16,159
    I believe the mirror comes with the wiring (you'll need to tap into a power source.. the dome is probably best).
    It's basically like the factory auto-dimming mirror but add the illumination.
  20. artistdr
    artistdr Junior Member
    30
    Oklahoma
    To which question are you yep'ing' to? ;-)
    Alan
    Quote:
    Yep. It's the amber/orange light. __________________
