I'm all Jacked Up!
Discussion in 'Gen 2 Prius Main Forum' started by DaddyLongLegs, Aug 26, 2004.
  1. DaddyLongLegs
    DaddyLongLegs Junior Member
    Gainesville, VA
    Just received my Canadian spashguards and they look easy to install. I have a 1 1/2 ton floor jack and would prefer to jack up the Prius using floor jack rather than the scissors jack that comes with the car.
    I noticed that there is a center support point under the rear of the car painted the same color of the car that looks like it was designed to be used as a center jack support. What about under the front of the car, what is the point that can be used for jacking? Anyone with experience in this area?
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    The document on this webpage... http://john1701a.com/prius/prius-oilchange.htm ...has photos of the point I've used.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    There's no need to jack up the front of the car at all...you can turn the wheels far enough for access.
  4. DaddyLongLegs
    Gainesville, VA
    Jacking it UP
    Ok, thanks for the info and the tips. However, what about a jack point of the rear? Can I use that painted center point extension protruding from behind the suspension to lift the rear of the Prius with the floor jack?
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    that pointed stub sticking down just behind the rear suspension center beam is the jacking point for the rear of the car if in doubt check the owner's manual. It's in there. On the front I use a spreader bar for my floor jack that extends across the front frame mount and picks up two points just inside the lower control arm inner mounts. It's very secure and has rubber pads on the end for a secure no slip mount. Take the saddle off the jack and install the spreader. Paid about 45$ for it. Put Jack stands under the car before working under it! Front and back. Better smart than smart and dead.
  6. norman
    norman New Member
    77
    Australia
    I applied my splashguards without removing the front wheels. I picked up a rightangle drill chuck kit which allowed me to drill the hole (through plastic, not metal by the way) at a 90 deg angle.
  7. DaddyLongLegs
    Gainesville, VA
    Thanks for the tips
    Installed the spashguards today with no problems. Thanks for the jacking info. BTW, the rear guards fit flush, but I added a matching small screw to the inside lip because the guard tends to warp away 1/4". Can't wait to test them in the rain, etc.
