I'm Going in for 60,000 mile Service. What Should I ask Toyota to Do and Look For ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by a priori, Sep 10, 2012.
  1. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    I'm closing in on 40 months and 60,000 miles. I know there are a few items with 60,000 mile warranties, and I want to be certain I ask the mechanic to take a look at them. Are there some TSBs out there that I should be aware of that may apply to my 2010 Prius V (Model 5, these days)?
    I've already discussed the transaxle fluid issue with the service manager, and I've yet to decide whether to pay the ~$150 he is asking. I haven't had any trouble with the car (and I'm not looking for any!), but I want to know if there are wear items to check.
    Suggestions? Comments?
  2. a priori
    3,083
    408
    23
    Chicagoland (West)
    Having heard nothing . . .
    I'm sitting in the waiting room at the dealership. My car has 59,866 miles and is currently in surgery (minor).
    I had the regular 60,000-mile service ($149) and asked for the transaxle service ($100). The tech then recommended the following:
    1. EFI service (cleaning)
    2. Throttle body cleaning
    3. Brake line flush (due to water found)
    4. A/C sanitization (recommended at 50,000 miles and I didn't do it)
    5. Alignment (based on uneven wear on the inner sides of the tires).
    No need to add suspense by having you guess which service I requested.
    The EFI and throttle body work seems like things to do together. They also seem to be things I should do if/when I notice a performance drop. Although my FE has dropped over time (less than 1 MPG per year), I don't notice any other issues, so I think I'll wait on this.
    The brake line flush seems like something of value if there is water showing up, because I do not want other issues to crop up. Not being a mechanic, I'm at a bit of a loss here, but I opted for this service.
    The A/C sanitizing is something I also opted for, because I already have enough allergy issues.
    Alignment will wait until after I get new tires. That will be happening within the next two weeks, so no reason to do it now.
    Comments?
  3. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    The EFI and throttle body service is not something that is on the scheduled maintenance it is often an item a dealer tries to talk people into. I have 93,000 miles on my 2010 and never had either done.
    Why would you have water in your brakes unless the lid was left open and water got in. That sounds like a scam.
    Who recommended a A/C sanitizer? It is not on the Toyota list? What do they claim they sanitize? The duct work in the car. This sounds like a bigger scam.
    Alignment is something you get if your car is pulling one way or the other. Or bad tire wear. Have you hit a curb or do you have a lot of pot holes? I would wait until you get new tires. Have a tire store check the alignment.
    All dealers are scumbags and they will try to nickel and dime you on worthless items. It is clear that they are doing this today.
  4. a priori
    3,083
    408
    23
    Chicagoland (West)
    I wondered the same, and I rejected the "offer" for the work.
    I also wondered the same, and I was told this was something that happened because of a particular line they used. It sounded to me more like a design flaw, but I bought it. If there was water in the brake fluid, it needs to be removed, and I don't know another way to do it.
    This is one that has come up before with the Prius. I've heard of this and I've heard it recommended at 50,000 miles. I don't have a problem with this one.
    Exactly. I'll be getting new tires within a week or so, and I'll have the alignment done then.
    I don't know that I'd go so far as to put the "all" label on, but I would say most are doing their best to get a significant profit on their service departments.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There are many TSBs out there but most require the car to exhibit some symptoms before they can be applied. I would ask them to run through the list and see what apply to your car.
  6. a priori
    3,083
    408
    23
    Chicagoland (West)
    Good idea. I went through them and he said most didn't apply to my car. I asked why, and he said: "Well, they apply mainly to the older ones." I said: "Older ones! I took delivery in May 2009. Who has an older one?" We then looked on the Toyota system, based on my VIN, and it wasn't showing most of the TSBs. I then asked to talk with the tech/mechanic working on my car. He came up and talked with me, and I learned quite a bit more from him than from the service writer (as if that was a surprise).
  7. a priori
    3,083
    408
    23
    Chicagoland (West)
    This one continued to bother me, so I went out to the Service Writer to ask him about it. He kept saying that water could get in through the master cylinder, and I kept wondering how and whether that wasn't a design flaw. Eventually, because of the other questions I had, also, he asked the tech/mechanic to come talk with me. He was straight with me on the other things (oil change, cabin filter, transaxle fluid change, etc.), so I said: "What about this water in the brake line?" He was a bit confused and the service writer got busy doing other things. I pressed a bit more, and he said: "Oh. The brake line flush? That's preventive maintenance."
    It had me a bit peeved, but this was not long after the mechanic had talked with me about the transaxle fluid change. He said the fluid was clean and clear, just a little dark. He said there were no fines on the plug, which he said was a bit different, but not remarkable. He did say the fluid was very clean and didn't need to be changed. He also said: "Toyota says there is no need to change until well after 100,000 miles, but if it were my car, I'd change it at about 60,000." He also would go with 5,000 mile oil changes, but is fine with 10,000 mile intervals. Finally, he asked me if I could park my car away from trees, because the leaves were getting into the cabin filter and causing me to change filters earlier than necessary.
    All-in-all, I may have spent money needlessly on the brakes -- or not. At least I am doing my best to prevent damage (and give profits to the dealer).
  8. Judgeless
    1,821
    257
    Cleveland, OH
    I think the A/C sanitizer is the biggest scam. What do they do? Clean out the ducts?
  9. a priori
    3,083
    408
    23
    Chicagoland (West)
    There is some fluid or spray used that costs $19.95, and there is a $30 labor charge. All I know is that people have complained about musty smells from their air conditioning, and for me to have something like that crop up would be disastrous. I have significant mold/mildew allergies, so that would make my car a very uncomfortable place for the 1,500 miles I drive each month.
  10. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Brake fluid attracts moisture in the air and then corrodes the brake lines. Worse, moist brake fluid boils a lower temperatures, and boiling brake fluid will not stop your car.
    Your locale will determine how much moisture is in the air, Tuscon AZ may go decades, Miami FL may be every 2 years. I do not know how moist Chicago is, but that is where the water comes from.
    Brake fluid - Wikipedia, the free encyclopedia
  11. a priori
    3,083
    408
    23
    Chicagoland (West)
    Chicago: humid July-Sept, a little bit humid April, May, October, fairly cold and a bit drier the rest of the time.
  12. Mendel Leisk
    40,586
    The Fuel Injector Cleaner (EFI?) is likely useless.
    Throttle Body cleaning might be a good idea, *if* they're actually digging down to it and cleaning it directly, not just spraying a can of something into the intake. There is recirculated gasses (out of my depth, not sure if it's Exhaust Gas Recirculation, or Positive Crankcase Ventilation) that can be re-introduced just upstream of the throttle plate, and they can gum it up.
    There is a *specific* cleaner for throttle bodies, a little different than regular carb cleaner. It's hard to find, though. I'm not sure, but I believe regular carb cleaner may be too harsh (out of my depth again, though). Also, there might be some sort of molybdenum coating just at the throttle pivot point. It's best to avoid cleaning right there, it might come off, leave the pivot too dry.
    Honda recommends brake fluid flush every 3 years for their vehicles, regardless of mileage. It doesn't take some unusual incident: it's just assumed over time brake fluid degrades, accumulates water.
    Air Conditioning sanitation is likely a waste.
    Alignment *might* be warranted, but: if you haven't hit a curb or something like that, or are feeling vibration/pull, it's likely just a come on. Considering the other dubious items on their list, I'd hold off, and if you're really concerned get an independent alignment shop to check it.
  13. a priori
    3,083
    408
    23
    Chicagoland (West)
    I figured that because I haven't noticed any performance drop, I don't need to spend the time and money for this service.
    I've heard similar things from others. To me, this seemed to be a safety and maintenance issue, so I felt it worthwhile.
    Perhaps, but having heard of many people concerned with the development of an awful smell related to A/C, and considering my allergy issues, it was worth the $40.
    I think I'll have this "straightened" out when I get new tires, sometime within the next week.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    AC cleaning was the best bet. EFI and brake flush a complete waste. Should have got the INverter coolant changed and the trans fluid changed.
    The AC cleaning is an excellent idea and have done my 50,000 mile Gen II twice myself. They use a pressurized can of foamy microbio cleaner. The can has a nifty hose adaptor. They plug that hose/can into the rubber drip hose under the car and fill the e-box under the dash with cleaning foam. It quickly turns too liquid and drips back out. It does 3 things:
    It removes any fungus from the ebox which the Prius is prone too. See "stinky"
    It removes any crud that may be building up in the ebox. This is important as that crud is the major reason the drip line gets clogged down the road which really sucks because you do not know its clogged until you see the pass side carpet soaked with nasty condensate. Hilarity ensues. Best $40 you will spend on the car.
    Makes the car smell 100& better.
    It is AC maintenance. That and take the top black plastic engine cover off so you can see the front AC condenser. Hose that down with Home D foamy coil cleaner. Rinse off real good. ge all the bugs and debris out. Look at it carefully for FOD. Just made the AC about 10 degree's cooler.
  15. a priori
    3,083
    408
    23
    Chicagoland (West)
    Thanks for the input. Didn't do the EFI, but I did change the brake fluid. I've now had many people tell me that the Prius is no different from other cars in that the climate here in Chicago will allow water infiltration and that the brake fluid will need to be changed every three years or so.
    Don't know that he inverter coolant needed a change, but I wanted the transaxle fluid changed, so I had that done.
