I'm gonna add non-spooling lap-belt AKA "racing seatbelt".
Discussion in 'Gen 4 Prius Accessories and Modifications' started by The Big Sleaze, Aug 13, 2022.
  1. The Big Sleaze
    276
    60
    'frisco
    2020 Prius
    Two Eco
    Like this unless I run across something classy in a junkyard.
    Should be easy and SHOULD just sit over factory metal connector.
    Reason is the first thing you learn about sporty driving is you need to anchor at least your pelvis so you don't need to use your arms and legs just to stay in correct seated position. I'm not PLANNNG anything too sporty, just worried about if I need to do some emergency maneuvering when someone spins out or pulls out in front of me, etc.
  2. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    I'm thinking of adding a non-spooling belt too. Did you get the Moheen and, if so, how do you like it?
