I'm looking for a higher mileage Prius (~100-150k miles), what problems should I watch out for?
Discussion in 'Gen 2 Prius Main Forum' started by roflwaffle, Feb 23, 2012.
  1. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I'm planning on going up a fairly steep hill from about 55mph to about 75mph to see if I can tax the pack and pull any error codes, but does anyone else have any ideas as to what I should look out for/test if I'm buying a higher mileage Prius?
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    Rectal exam: stick your finger in the tailpipe. If it comes out slightly rusty or cleaner, its perfect. If it comes out black, it is consuming oil, the cat will be short-lived. In California, you are screwed if your have a bad cat outside of 10/150 warranty.
    It's really hard to get the car to trigger a DTC when there is a marginal pack. If you take it up Cajon Pass and have no drivability issues, the battery is probably fine.
  3. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Yeah, cats are expensive, but at least it's smog exempt in CA. The grade I'm thinking about on the 241/91 isn't as long, but it's as steep. What kind of driveability issues would I notice with a weak pack?
  4. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    SoC drains rapidly to 1 bar and the car will barely go.
  5. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    That's easy enough! Are there any specific systems that need special attention besides the usual fluid leaks, potential suspension issues, and so on?
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If you're looking for a high mileage GenII I would be tempted to sell mine. Most of the stuff I've modified could be turned back to stock fairly easily. At least you'd know the history of the car. lol
  7. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    ...that is, if OP is willing to read thru your 11,820 posts!
    OTOH OP might want to look at Sticky note about typical issues with Gen-II
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Good point! Hahaha
  9. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    That would be great, but I'm not seeing it in the forum stickies. Do you happen to have a link?
  10. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
  11. Wimble
    Wimble Junior Member
    30
    uk
    Aside from mechanical factors - I found a massive variation in the interior quality of used Gen 2 when I was looking. This is largely to do with owner care, but as the inside is where you be spending your time driving, it's worth merely looking at a number of models with similar mileage to ensure you get value for money. I would even personally sacrifice a few miles for an interior that is near spotless, assuming that the mechanical elements are in order.
