Im only getting 500-550 miles on a full tank of gas!
Discussion in 'Prime Main Forum (2017-2022)' started by Phuie024, Aug 21, 2017.
  1. Phuie024
    Phuie024 New Member
    San Jose, CA
    Hi recently i tried to pump a full tank of gas and drive it without charging and i can say i didnt get nearly the 600 miles toyota is advertising. Now i dont have a heavy foot and i dont hypermile or anything. i pretty much drive normally. What is everyone else getting on a full tank?
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    What was the MPG displayed? Calculated? Miles? Gallons?
    In other words, we need more info.
    Also, what about your roof rack?
  3. TinyTim
    TinyTim Active Member
    366
    224
    Seattle
    Without charging your battery on a full tank a Gen 4 prius should get anywhere from 500-575 miles before running on empty. I can get 550 miles without much effort but usually fill up in the 525-530 range unless I know where I am going and where a fuel station is. Unless you want to keep a gallon of fuel in your car, which I think you should do at least once in your Prius life. That really is the only way to tell your true range for fuel. I have never filled my tank with 10 gallons or more of fuel. The most fuel I have seen on the gas pump is from 9.6-9.8 gallons. The manual and others here have said the fuel tank in gen 4 prius is 11.3 gallons. I think the tank is closer to 10 gallons.
  4. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,303
    3,519
    Anaheim, CA
    I had problems filling to max on my 2012 PIP; it would click, indicating that the tank was full. Usually I learned to keep pumping (not recommended), which would yield as much as 100-150 miles more range. Since I've filled so rarely with the Prime, I've not yet figured out the characteristics of this car's gas filling process.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    That is a mostly meaningless measurement.......because each "tankful" will likely be a different amount.
    If you want to test and compare, track miles driven and gallons used.
    fuzzy1 and HPrimeAdvanced like this.
  6. bisco
    49,489
    you made the rookie mistake of not running it dry.
    mercat68, Trollbait and TinyTim like this.
  7. TinyTim
    366
    224
    Seattle
    May I suggest a thread for max miles before running on fumes? Rules of such a thread requires a photo of miles driven on a tank and fuel level. All based on the honor system. The only requirement. A 1 gallon fuel can must be on board as well as photographed. Seasonal driving records for spring/summer vs. fall.winter driving (more ethanol in gas) with separate categories.
    bps, HPrimeAdvanced and bisco like this.
  8. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    You didn't drive it slow enough. Try 25 mph throughout. The car is so energy efficient that the gas keeps overflowing out of the tank. The longer you drive, the more gas it generates!
  9. Tideland Prius
    16,155
    Are you pumping at the low fuel light? If so, 550 miles is pretty good. Remember that you have a reserve. Toyota's 600+ number includes running the tank down to 0 (which no one does). Depending on your mileage, the reserve is good for at least 60-80 miles in the summer.
    e.g. on my Gen 3 with a 45 litres (11.89 gal) tank (Gen 4 & Prime have 43 litres/11.36 gal), the low fuel light comes on at the 35th litre (9.25th gal) so I have 10 litres (2.64 gal) in reserve. My record tank had the light come on at 823km (514 miles) and I drove another 132km (82 miles) on the light and refuelled at 955.5km (597 miles) and pumped in 40.9 litres (10.8 gal). I still had 4 litres (just over 1 gal) left so I probably could've hit the 1,000km mark with 2 litres left (0.5 gal) but without actual numbers, I was just going on estimates. The MID read 4.1L/100km (57mpg) while the hand calculation was 4.29L/100km (54.8mpg). Recall that the Gen 3 is rated for 51/48/50mpg (revised 2017 numbers are 50/46/48 mpg)
    So you use that as a guideline for your Prime.
  10. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    I think your post may have a bit of gas in it, if I'm not mistaken, perhaps some hot air maybe??!!
    priuscatprimeguy likes this.
  11. TinyTim
    366
    224
    Seattle
    My personal best is 580 miles on a Prius 2 tank. On a prime add 23-40 miles for a fully charged prime to that number. I didn't have a gallon of fuel in the back to push it further. I lost my nerve @ 580 miles. I think on a standard Prius or a Prime with no charge you shouldn't have to start looking for a station until 550 miles.
  12. bwilson4web
    15,523
    <AHEM!>
  13. bwilson4web
    15,523
    To "low gas" warning light, this is correct. However, I've measured ~1 gallon of gas still in the tank when the warning light comes on: Prius Prime Plus in my hands | PriusChat
    BEST PRACTICE: when "low gas" light comes on, put the car in CHARGE mode and start looking for fuel. What you are doing is putting 25-30 miles of electric energy into the battery so when the gas is finally gone, the car will convert to EV mode and you must now decided where to park to get gas.
    WORST CASE: run the tank dry with no charge on the battery. It will set a flag that either can be reset by doing a 12V, power-on reset (aka., disconnect the 12V ground and reconnect AFTER adding some gas) or towing to Toyota who will do something similar and charge you several hundreds of dollars.
    #13 bwilson4web, Aug 22, 2017
    alexcue and HPrimeAdvanced like this.
  14. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    after 7 years of gen 2 ownership (4 different cars) I still don't trust any of the guess gauges .. some time I get 140 miles before it moves off full, some times 85 miles.. I always fill the same way at the same station.. so I just refill at 300 miles... id love to push it my with my luck id burn up the fuel pump and kill the battery..
  15. bwilson4web
    15,523
    Actually I somewhat agree. I've found tripmeter and MPG to be the best way to calculate how much out of the tank has been burned. The bladder tanks had some variability not seen since the Gen-3 and later.
    fuzzy1, HPrimeAdvanced and Beachbummm like this.
  16. Trollbait
    11,560
    I'm pretty sure that 600 number includes a full charge of EV distance.
  17. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    600 without and (confusingly) 640 with.
    Regardless, it depends on your mileage. I got 74.8 yesterday. That's 845 miles on gas (assuming 11.3 gallons) plus 30 or so on Ev.
  18. Phuie024
    Phuie024 New Member
    San Jose, CA
    thanks guys but I think I figured it out. I pump right when my low gas light comes on which as others have said in here leaves me with 1-2 gallons of gas left
  19. Lee Jay
    5,850
    4,024
    I measured about 1.5 gallons. So, yes.
    HPrimeAdvanced likes this.
  20. Tideland Prius
    16,155
    Correction: "which only Bob does" for science. :D
    fuzzy1, heiwa, jerrymildred and 3 others like this.
