I'm Still Confused About When to Use "Normal" Drive Mode
Discussion in 'Gen 4 Prius Main Forum' started by LoganLady, Nov 25, 2017.
  1. LoganLady
    LoganLady New Member
    Utah
    Three Touring
    I've just finished reading the owner's manual cover-to-cover. WHEN is "normal" drive mode the preferred mode? Does the battery still charge in this mode? Why shouldn't I use "Eco Mode" all the time? I couldn't find specific info about this.
    52,776
    welcome!
    there is no special 'time' to use power, eco or normal modes. it's your choice. try all three and see which one you like more.
    i have always used eco mode, because along with a long pedal travel, the hvac is suppressed.
    i'm not sure if that is the case in gen 4.
    some like power mode because the car feels faster to them, and some like normal because it's a good compromise.
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    So, here's what my 2016 manual says:
    Power mode's comments about "crisp handling" are hogwash, but basically it boils down to the following:
    Normal mode: Linear throttle
    Power mode: Aggressive throttle (more power earlier in the travel)
    Eco mode: Gentle throttle (less power earlier in the travel), and Eco mode automatically selected on the climate control system
    Note, however, if you floor it, you'll get full power, no matter what - so, as bisco said, there's no special time to use each mode. And, if you don't want Eco climate in Eco mode, or you do want Eco climate in Normal/Power mode, there's an Eco button on the climate control that can toggle that.
    Myself, I personally use Eco, even when I'm driving aggressively.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    First, with one exception, Eco, Normal and Power are just user interface changes, they do not change how the car works, only how you react to the accelerator and vice versa.
    Now for the exception, in Eco, the A/C is less aggressively trying to cool the car, what might take 3 minutes in Normal takes as long as 30 minutes. This saves energy, so saves gas. However, if the temp is over 90, I hate being hot for 30 minutes and switch to Normal from my usual Eco. In the summer, this is every afternoon for the first hour from a stop.
    kithmo, jerrymildred, RCO and 2 others like this.
  5. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    At least in the Gen 4, they changed things so that you can keep your preferred throttle mapping, and still get full blast AC, with the Eco button on the climate control.
    jerrymildred and RCO like this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I have not seen a Gen 4 stationary, let alone driven one, so I defer to those who have.
    It is nice feature I am sure, but I use cruise control 95% of the time, so throttle mapping is not relevant, so Eco for less A/C, Normal for more A/C, works for me, even on my v.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I prefer the more progressive ECO throttle response, particularly in tight traffic. None make any difference to Battery charging, mainly with how aggressively your throttle feels. I really don't think it's made any difference to my l/100km figure, I alternated between tanks with how I had it set.
    jerrymildred, RCO and pilotgrrl like this.
  8. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I prefer ECO mode, I like the gas mileage and it feels like what I'm accustomed to from my Gen 2. If I'd never driven a Prius before, perhaps I'd prefer Normal mode.
    I really enjoy DRCC for highway driving. Old fashioned cruise control put me to sleep driving through certain boring states between Denver and Chicago, the few times I tried it (pre-Prius).
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I use ECO to save fuel. DW doesn't like the lethargic pedal response and prefers PWR but since the car doesn't stay on PWR after restart, she uses normal.
    RCO likes this.
  10. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Also worth noting that the modes are different between Gen 3 and Gen 4.
    Gen 3 Eco: Very reduced throttle sensitivity early in pedal travel
    Gen 3 Normal, Gen 4 Eco: Reduced throttle sensitivity early in pedal travel
    Gen 3 Power, Gen 4 Normal: Linear throttle sensitivity
    Gen 4 Power: Increased throttle sensitivity early in pedal travel
    So, someone who likes Power in a Gen 3 will probably like Normal in a Gen 4. And, as this is the Gen 4 forum, and the OP has a Gen 4... the setting will stick wherever you leave it.
    Mendel Leisk, mmmodem and RCO like this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Cool! You could hide the entire UK in some of your United States. :sneaky: but who'd want to?
    pilotgrrl likes this.
  12. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    I applaud you for diligently slogging through the entire manual! Your patience is greater than mine. There are lots of opinions about driving mode. I say leave it in normal mode, and just drive it! Be sensible about acceleration, braking, etc., and the car is smart enough to get great mileage. Essentially, the other modes only affect the responsiveness of your accelerator.
    XT1710-02 ?
    kithmo and RCO like this.
  13. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I always use normal, it feels just right for me as I am able to feel and know when the ICE is going to cut off and its gives a good compromise of acceleration and economy. As others have said if you suddenly need to accelerate quicker than normal you just punch the throttle and it overrides whatever setting you are in anyway and gives you full power, so no need to think you have to press the mode button.
    I find Power mode a bit too aggressive personally and it feels a bit on or off rather than being progressive. I don't know if regen is more aggressive in power mode, but it feels like it, but probably because its slowing quicker because the car accelerates quicker?
    I have used Eco even less than Power, its all personal choice.
    kithmo, RCO and pilotgrrl like this.
  14. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Actually, throttle mapping changes the way the cruise control accelerates as well on my Gen 4. When the car is slowed for traffic, or when faced with a hill, PWR mode returns to speed much more quickly than ECO, in my experience.
    kithmo, RCO and alanclarkeau like this.
  15. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I too almost always drive in ECO mode. Then again, I drive a P.Prime (I gather you’re asking in terms of a non-Prime Gen-4) and almost always drive it in EV mode, other than for road trips. With the P.Prime in EV mode it’s strictly a difference of throttle-mapping: zero- and full-throttle are the same in all three modes.
    However, since I pretty rarely drive on gas, I must ask: Is that true in hybrid mode too — that when you floor it you get equally full power in any mode?
    RCO likes this.
  16. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Those who drive in real winter, don't use eco mode when you want lots of heat to keep windows clear. Lesson I learned the first winter with Pearl S. The heating system works much better in "Normal" and "Power" mode. I also stay out of "Power" mode on slippery surfaces. Easier to control wheel spin in "Normal" and even easier still in "Eco" modes. Oh, and yes, the Prius -can- spin the wheels, just not a lot. ;)
    Theone23, jerrymildred and RCO like this.
  17. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    As JimboPalmer mentioned above in #4, you can leave the Gen 4 in ECO driving mode and put the climate control in Normal or Eco, a nice feature.
  18. Fester
    Fester Active Member
    201
    198
    Ohio
    Its's also the mode that car salespeople favor...
  19. bisco
    52,776
    you got that right. first words out of every prius salespersons mouth, 'put it in power mode, it's not as slow as people think.'
    Theone23 and RCO like this.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    All in all, I personally think it is fairly peppy in Power Mode. Hardly a sports car, granted, but hardly slow either. It’s fun, but I personally rarely have any real need for that extra power.
    iPhone ? Pro
    #20 mr88cet, Nov 26, 2017
