I'm thinking of buying LED low beams vs. HID low beams. Does anyone have experience with both?
Discussion in 'Prius c Accessories and Modifications' started by legoadan, Aug 27, 2014.
  1. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I was looking at HID kits and LED kits and have been swayed more into buying and LED kit. The kit I want is a bit expensive but it should be good for the life of the car (it also comes with a no questions life time guarantee).
    I know there are cheap HID kits and cheaper LED kits, but I want something that works, is bright and will last.
    I was looking at the Xenon Supply HID kit and the GTR Lighting LED kit. Any thoughts?
    Xenon Supply HID
    GTR Lighting LED
    Just want to here some opinions. I don't have a huge amount of people to talk to about these things IRL.
  2. DKTVAV
    DKTVAV Active Member
    510
    101
    I'm using DDM HID kits for more than 2 years and still going strong with 1/3 of the Xenon's price.
  3. xliderider
    xliderider Senior Member
    7,914
    3,141
    Honolulu, HI
    The GTR LED light pattern at the link you provided are terrible. Especially the pic that shows the light pattern in a totally dark room, with the light emanating only out the sides of the "light". This is nothing like the near point light sources like you gettm with a halogen bulb filament or an HID arc which disperse light in a nearly spherical pattern.
    I use modified H9 65w halogen bulbs in place of the 55w H11 lowbeam bulbs in both of my cars. Quality Osram or Philips H9 bulbs cost about $8 each from Amazon and put out about 2200 lumen per bulb of bright, white 4300k light. Very good output compared to the stock H11 bulbs. Link to the H9 conversion is in my signature below.
    SCH-I535
    #3 xliderider, Aug 27, 2014
  4. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    What do you guys think of these?
    Here.
  5. xliderider
    7,914
    3,141
    Honolulu, HI
    Read through the 1 and 2 star reviews.
    SCH-I535
  6. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    The H11 bulb from ddm tuning is very loose, so you have to tape it with electrical tape or the better but more expensive kapton tape.
  7. Topher
    Topher Member
    32
    32
    Pasadena ca
    The new 2014 corollas have led head lights they look beautiful I say go to the dealer and check those out.
  8. xliderider
    7,914
    3,141
    Honolulu, HI
    Comparing oem LED to aftermarket replacement LED bulbs are apples and oranges.
  9. hackenfort
    hackenfort Member
    62
    40
    2016 Prius c
    I put the new 2400lm led a in my prius and love them. Much brighter and whiter than stock. Instant on too! Coming from HID I was nervious but I've been using them for the last two months and I'm very pleased. Just a FYI they are not so good for the hi-beam.
  10. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    I purchased the Xenon Supply HID Kit and they work great. However I've only had them for 9 months.
  11. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I have the Kensun 35W version and have had no problems in the two plus years since installation. I did buy some wire/plug adapters on ebay so I could remove everything. if I had problems
  12. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    Any thoughts on getting 35w vs 55w?
  13. xpcman
    1,302
    295
    I figured 35W would put less stress on the system. I spent about $10 to buy some H11 wires/plugs since the Kensun kit just had bare wires on one end. I was not too pleased that the kit was not "plug and play".
  14. xliderider
    7,914
    3,141
    Honolulu, HI
    There could be a heat consideration, the 55w HID would run hotter than the 35w HID and even the oem setup.
    Other members here have 55w HIDs, but no one has reported any problems with reflector bowl discoloration or melting, etc. Likewise, I haven't had any problems using 65w H9 halogen bulbs either.
  15. yibo829
    yibo829 Junior Member
    84
    Try the "the retrofit source". They have great products.
    iPod touch ?
    Mo G likes this.
  16. Ecobill
    Ecobill Junior Member
    94
    Berea OH
    2014 Prius c
    Thanks for the excellent video. Who would have thought is was so easy. I'm glad you took the time.
  17. varun singh
    varun singh Member
    113
    Wayzata
    Can you post the links from where you bought 2400lm LED bulbs, please :), Thanks
  18. formula
    formula Member
    320
    32
    CA
    I found some on ebay.
  19. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Ditto.
  20. AliIzad
    AliIzad Member
    170
    72
    Southern California
    I have been using the Xenon supply kit for over 2 years without issue and they have been great. They are however just starting to lose some of their "whiteness" (lack of a better term) and are taking longer to warm-up. But, now I'm intrigued regarding LED, especially hackenfort's set-up (9th post).
