I'm worried; guess gauge didn't change after 3.5 gallon input
Discussion in 'Gen 2 Prius Main Forum' started by jsnschmasn, Apr 5, 2008.
  1. jsnschmasn
    jsnschmasn New Member
    17
    St. Louis, MO USA
    Hello all,
    I'm just wondering if I should be worried. I wanted a car wash and filled-up when I was at the gas station. It took 3.44 gallons but the gauge(not the mileage indicator) did nothing. It remained at 6 pips as it was before I filled. Any need to worry or should I just let it sort itself out?
  2. prius729
    prius729 New Member
    120
    Hobbs, NM
    let it sort itself out.
  3. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    My manual say's that if you add around 3 gal the gauge may not change. I would say it is nothing to worry about.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It takes three gallons or so to register. In your case, the gas was added to the top of the tank, part of which is not sensed by the fuel level sender. You didn't add enough for it to register. The same amount added to an empty tank would work.
    Tom
  5. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    Moderators, there should be a minimum requirement (in gallons) to start a thread :pound:
