Impact of Fan to EV Miles
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SimiPrius, Mar 29, 2012.
  1. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    I realized today that if I turn off the ventilation system completely, my EV range goes up by 1.2 miles. It does not seem to matter whether the AC is on or not. The fan seems to be an EV hog. Is anyone else seeing this much of an impact on their EV range?
    Thanks
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I have seen an impact, but I dont recall seeing that much of an impact, usually something around 0.5-0.6 miles, if I recall.
    Maybe it depends on whether you have a full battery or not. If you have 12 miles EV range and it thinks the fan may be on over the whole range, then it's estimating that the loss over the 12 miles may be 1.2 miles, for example. But if you turned the fan on with only 6 EV miles left, it would be less of an impact (which is my case from what I remember).
    I'll try it out when I leave work today.
  3. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
  4. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Yes, i've seen that a few times recently.
    Pollen wasn't bad today after coming back from meeting 9Gman, and opening windows and turning off fan got me the last mile home with 0.5 EV left.
  5. LenP
    LenP Member
    257
    69
    Morris County, NJ
    I don't think your really loosing all that mileage running the fan. I think again it's the computer estimating what it thinks might happen. All you can do is drive and see. Try setting the temp to Low then see if you get the same result with the fan.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    House fans are around 40 watts. If the ~ 3 kw of a full traction battery are used up in 30 minutes of driving, the fan is responsible for 40/6000 = less than 1%, equal to 425 feet of range. If the 'c's fan is a monster at 120 watts, then it has grabbed 2% of the capacity, or about 1200 feet.
    Regardless, I would not be quick to turn off the fan. It cools the battery, too.
    Those interested in estimating fan power draw can derive the number from the car's estimate of range remaining while the car is running at say 30 mph and 40 mph, fan on or off.
    ps -- I wonder what the car says when the fan is turned on and the car is stationary LOL
  7. kstitt
    kstitt Junior Member
    San Bernardino
    I have also notice that the projected mileage decreases by 1 mile when the fan is turned on. I haven't been able to do a controlled test to see what the actual degradation is.
  8. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    I agree what you're noticing is just the Estimate of the computer.
    Document the miles with and without the fan two days in a row.
  9. LenP
    LenP Member
    257
    69
    Morris County, NJ
    I tried the fan tonight, heat and AC off, and it did drop like a rock, yet a few days ago I had it on for my whole trip and still got 12 EV range.
  10. flim
    flim Active Member
    207
    141
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    My fan was set to low last night and when I turned off the fan my EV miles jumped from 5.4 to 6.0 miles.
  11. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    When I left work I had 11.9 EV miles. I turned on the fan and it dropped by 1.3.
  12. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    I can only speak from a standard Prius perspective, but the fan running at two bars will drop the battery a bar after a few minutes while waiting for someone at a store, add AC and it drops drastically! I imagine it's the same for the PiP.
  13. Kahuna69
    Kahuna69 Junior Member
    43
    Arizona
    A/C drops charge from 12.7 to 11.3 here in Arizona. Drops at least a point.
  14. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    I don't have a PiP, but I have a similar experience with my Leaf. If I turn the vent on, the range estimator drops the same as if the A/C compressor were on. I think it just looks to see if the HVAC system is on or off and doesn't pay much attention to what the actual setting is. Typically I crack or roll down my windows leaving the A/C off completely unless I have passengers in the car. I've always been like that, even when I drove a Prius and even before that with standard gasoline cars. It just seems like a waste of energy to run the A/C when there is cooler air outside.
    I'll admit that during July and August here in Texas, I do find myself running the A/C, though.. 106 degrees is just too hot.
  15. LenP
    LenP Member
    257
    69
    Morris County, NJ
    But did your trip to work come up 1.3miles less in EV mode less?
  16. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I dont use the fan at all right now.
    I've been consistently getting to work with about 1.0 to 1.4 miles of EV range remaining (and this is leaving the house with ~12 miles EV displaying and a 13.4-14.5 mile commute). If I remember to, I'll try this on my Monday morning commute and see what I end up with when I get to work.
