Impacted radio dial
Discussion in 'Prius c Technical Discussion' started by Mr. Man, Oct 1, 2020.
  1. Mr. Man
    Mr. Man Junior Member
    89
    Chicago
    So, today I accidentally put a lot of pressure on the radio’s main volume/power dial and it sort of impacted. It’s still functional but will be much harder to manipulate, especially while driving. I tried to pull it forward again, but it no longer sticks. Hope you’re able to follow my sloppy description.
    I have a 2013 Prius C.
    Is there anyway for me to fix this without taking it to a dealership and paying a lot of money?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
    Just pull off the radio knob. See if it is crushed or broken, If it is, a replacement costs about $3 at the dealer. Cheap fix.
    RobAustin and Mr. Man like this.
  3. Mr. Man
    89
    Chicago
    OK, I may try this. But what if I find that something else has broken, something that won't be fixed by replacing the knob? Then I'll be stuck with (what I assume will be) an expensive repair, and a radio I can't use until I pay it. That's my (perhaps unreasonable) fear, at least.
  4. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    Not really expensive. That radio is really cheap on eBay. It is often sold by those who have made an upgrade.
    AzusaPrius likes this.
  5. Mr. Man
    89
    Chicago
    sorry to bug you, but I just went down to my car to check and as fate would have it, I actually noticed the hazard lights were blinking rapidly and weakly. I had accidentally left them on for something like 4 to 6 hours. Very lucky that I caught this. I went inside the car and it was clear the battery had been drained a bit. After I open the door, even though the car had not been started and the key not inserted, the car started making some weak puttering sound. It kept going for a minute or two.
    Do I need to be concerned about this? Any long-term effects? Or will it just be better by morning?
    #5 Mr. Man, Oct 1, 2020
  6. ChapmanF
    18,580
    You will want the battery fully charged again. That can take several hours of leaving the car in READY (if your location is safe for doing that)—if it has enough juice left to go READY. Otherwise, a battery charger (or a jump followed by the several hours in READY).
    Mr. Man likes this.
  7. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    I always use a slow charge battery maintainer. Fast charging is bad for a battery but sometimes can't be avoided.
    Mr. Man likes this.
  8. Mr. Man
    89
    Chicago
    My location isn't exactly safe for that, I live in the city and use street parking.
    "READY" mode - is that when I insert the key but don't start the engine?
    Sounds like I'm going to have to sit in this thing for a few hours..?
  9. Mr. Man
    89
    Chicago
    Is a "fast charge" what will happen if I just go to the car tomorrow and attempt to start the engine like normal?
  10. Mr. Man
    89
    Chicago
    So for the record - - I should not just go and start this car tomorrow morning?
  11. ChapmanF
    18,580
    I'm guessing the charging in a c is pretty much like the Gen 3 liftback, so it will charge the battery somewhat faster than a Gen 2 would. Still, even in old conventional cars that would really whomp the battery recharging from a jump, people would do it anyway if it was what was easiest.
    It may shave some indeterminate amount off the lifespan of your 12 volt battery. The question is, whenever it comes down the road that you're standing at a counter buying the eventual replacement battery, are you going to be saying to yourself, "curses! if only I had used a slow charger back in October 2020 instead of simply jumping, perhaps I would be doing this n months later!"?
    Sometimes you just do the thing that solves your immediate problem, and go ahead with your day.
    Mr. Man likes this.
  12. Mr. Man
    89
    Chicago
    Good answer, friend.
  13. ChapmanF
    18,580
    By the way, I missed the question about READY mode. That's when the word READY lights up on the dash, which happens when you do "start the engine".
    Nothing is getting charged unless READY is lit up.
    Mr. Man likes this.
  14. Mr. Man
    89
    Chicago
    Well - tried to start the car, battery's dead.
    Guess I'm hoofing it to AutoZone to start buying things.
  15. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    Did you ever get the radio button fixed?
