Impending ABS Problems?
Discussion in 'Gen 2 Prius Main Forum' started by Jordan.luna, Dec 17, 2019.
  1. Jordan.luna
    Jordan.luna New Member
    Roswell
    Hello! I have a 2008 Prius with about 134,000 miles on it. I have had it for a few months now. It has basically always made the chirping/barking noise when applying the brakes and through research I know it is the sound of the abs actuator. The sound is quiet when lightly applying the brakes and gets louder when I increase pressure. The sound is not constant and sometimes I don’t hear it at all. When I first got the car, I took it to a hybrid shop for a separate brake issue and they said everything was fine and had no codes for the actuator even though the brake/abs/vsc lights were on due to that separate issue. When I was going through the service records, I see that the actuator was replaced under warranty in 2017 by Toyota when they were doing them for free. Just being the nervous car owner I am, is the noise a sign that the part could be going bad again? Is there anyone who has had to replace the part multiple times? Thanks in advance!
  2. PriusCamper
    PriusCamper Senior Member
    13,022
    5,292
    Pacific Northwest, USA
    If you can take it back to the dealer that did the work for a free follow up inspection that would be ideal. Just don't give them money, just have them check their work. Some Toyota Car Stealerships are amenable to such requests.
  3. Jordan.luna
    Roswell
    The only problem is, the work was done at a dealership in Florida where the previous owner lived. I’m in Georgia
  4. ChapmanF
    18,513
    Might try a brake bleed sequence just to see what happens. My guess on the honking sound is valves in the actuator acting as saxophone reeds while small gas bubbles in the fluid go through them.
    Jordan.luna and PriusCamper like this.
