Importance of checking tire pressure regularly!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Sep 20, 2013.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I am guilty. Because I have a new car, I havent checked pressures in about 6 weeks. Tires were set 6 weeks ago at 40/38. Today I had them checked and they were at 35/33. I was shocked! That is a 5 pound drop in about 6 weeks. Temperatures were a bit cooler this morning but I didn't realize how much temperature can affect pressure and probably how tires lose a pound or 2 pressure just as time goes by, say in a month or so. Moral of story is: check your tire pressure regularly, especially this time of year as temperatures drop. I'm sure I wasted a gallon of gas or more over the last couple of weeks. I certainly am going to check it more often.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    So Cary are you the Girl or the Boy in the picture?
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Does it matter JMD? lol
    The tyre pressures can change with significant changes in outside temperature. Always good to get into a habit of checking them fortnightly at least.
    JMD likes this.
  4. JMD
    3,779
    1,282
    Grumpy it's a guy since it said member male
  5. chandler
    chandler New Member
    ATL
    The rule of thumb is for every 10° Fahrenheit change in air temperature, your tire's inflation pressure will change by about 1 psi (up with higher temperatures and down with lower).
    BruceInOKC likes this.
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    If you re-set the TPM at 40, you should get a warning if they drop to 35 or 34.
  7. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I suppose you have to go to a toyota dealer to do this and pay them $50-100 for the reset?
  8. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Its in the manual, button is under the dash left of the wheel. Push and hold till you get flashing indicator on the dash.
    You could also pump them up to 42-43, then reset, then lower to 40, then it will warn you sooner.
  9. N2MPG
    N2MPG Junior Member
    30
    Radford Va
    That is genius right there..
  10. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    FYI
    Tire pressue is sensitive to atomospheric temperature. Example if you have a fall weather cold front move thru your local area which is happen here you will realize some tire pressure loss. I am not fan of early TPMS systems the tire valve insert monitor is a hassle. I find for me far more easy to just rotate tires and routinely check my tire pressures......
  11. NortTexSalv04Prius
    915
    115
    Nitrogen mix has been claimed to better maintain tire pressure than just shop air pressure...........
  12. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    All "air" is 80% nitrogen. ;)
    GrumpyCabbie likes this.
