Improve 2015 Prius V Two headlights
Discussion in 'Prius v Technical Discussion' started by MalibuBill, Oct 21, 2024.
  1. MalibuBill
    MalibuBill Junior Member
    Baja Oxnard
    2015 Prius v wagon
    The low beams on our 2015 Prius V Model Two are inadequate. Is there an aftermarket upgrade for these lights?
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,563
    5,869
    Texas Hill Country
    Yes. I use the Lasfit versions. Don’t buy low cost leds as most will create rf noise which can impact the cars ecus. Some cheap versions have bad aim. LEDs run hot so they have built in fans which can whine. I would spend at least $69 a pair.
    Product Result – Lasfit®
    #2 rjparker, Oct 21, 2024
  3. Air_Boss
    Air_Boss Senior Member
    4,135
    1,152
    New Yawk
    I have used both Lasfit and Oxilam LEDs to replace what were OEM incandescent/halogen bulbs on both high and low beams, in both reflector and projector housings, and found the lamp metrics and fit with the optics on both to be excellent. Sharp cutoffs, no random blinding.
