Improve Shocks and Driver's Seat Replacement for 2016 V.
Discussion in 'Prius v Accessories and Modifications' started by EastR, Jan 28, 2025.
  1. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    It may be a big ask, but I am trying to improve drive comfort/shocks/pothole handling and an uncomfortable driver's seat for an aging dad with a bad back in my 2016 Prius V without having to get a new car since this one only has about 60K miles and wanted to consult the brain trust here.
    I've read the relevant threads and come up with the below recommendations for either coilovers or new shocks but can't tell why one is $2k and the other $440 and want to know if either of these would significantly improve pothole comfort or if anyone recommends the sway bar/stiffeners for this project.
    Coilovers: RS-R
    Tein Endura Pros: Tein EnduraPro Shocks for 12-16 Prius V Hybrid (Front & Rear Set) | eBay
    I'm currently on 205/60R-16 CONTINENTALTRUECONTACT TOUR SL tires. For the driver's seat, I have the three trim with lumbar support/adjustment but the foam padding/seat comfort is severely lacking now that it is a 10-year old car. Would you all just recommend taking it to an upholstery shop to re-fill/replace the padding all around or is there a way to install a OEM or aftermarket driver's seat that isn't prohibitively expensive. Appreciate any and all guidance on this - the new Corolla Cross Hybrid is nice but is also goes for about $32k locally.
    Last question - I went to a local shop last year but ended up with a dealer replacement of the warranty brake actuator -- the shop said the "control arm bushings are starting to wear and the stabilizer bar link is torn" and recommended a replace front lower control arms and front sway bar links and alignment for $2,151 ($1573 labor and $448 parts with $130 alignment). Is this connected to handling and could the shock replacement/improvement above be done together with the control arms? Some blurry photos from this diagnosis are attached.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,485
    5,808
    Texas Hill Country
    First any aftermarket struts will make it ride stiffer. Some guys like this but it is the opposite of what you are looking for.
    IF the factory struts up front and the factory shocks in the rear are not leaking they are fine. If they are leaking get new oem parts for best ride.
    Tires and tire pressure make more difference. Set tires at the door sticker pressures and don't over inflate for mpg.
    When it's time for new tires get Michelin A/S or Defenders. They ride better.
    Front seat- factory lumbar is not enough, try a lumbar pillow on the upright seat back. Big difference. If he is tall recline the seat back more with the lumbar pillow.
    A Prius v will never ride like a Lexus or modern Rav4. It is made for decent mpg and for increased cargo than a hatchback.
    Front end parts with loose bushings? Find a reasonable small shop with an alignment machine. The front end sway bars etc are a standard design any shop can do in their sleep. Generally they do not seriously impact ride comfort. A clunking might be heard. 60k is too short to be serious issues. My 320,000 v has original suspension, struts and shocks. And is driven in South Texas heat greater than Florida and close to your humidity.
    #2 rjparker, Jan 28, 2025
  3. douglasjre
    douglasjre Senior Member
    2,085
    698
    Null, NL
    KYB brand at RockAuto.com
  4. Kenny94945
    Kenny94945 Active Member
    839
    417
    Sausalito
    2016 Prius v wagon
    Well, you have bad suspension rubber.
    60K miles on OEM shocks.
    Dad, who experiences pain while driving.
    Geez, I don't know for sure.
    Guess I would start with repairing the damaged suspension rubber.
    The pot hole discomfort may be that the shocks are bottoming out from being worn out or it is the damaged suspension rubber.
    Might be cost effective to do the shocks at the same time.
    As for "Rock Auto" aftermarket, KYB etal vs OEM, I'd be swayed with OEM as you know the baseline feeling.
    The KYB etal may be too stiff.
    Yes, I would consider replacing the seat foam.
    Old age is not recommended LOL.
    Good luck.
  5. douglasjre
    2,085
    698
    Null, NL
    Where did you get your automotive knowledge from?
  6. Joele3
    Joele3 Active Member
    128
    192
    Bay Area
    I have the Tein Endurapro shocks and struts on my V. When I went to install them I ordered some springs with it. They ended up sending me the three different types. Go figure, dropping the V wasn't meant to be that day. The Pro shocks/struts are adjustable I have dialed them in the middle setting. Rides like a lowered car without being lowered! I haven't tried them at their softest but I'm very satisfied over the OEM ride. Ive got around 120K on em so far. No issues but im still getting that itch to drop it. I keep waiting for an excuse to replace my struts. They dont ride like new but still going strong.
  7. xliderider
    xliderider Senior Member
    8,032
    3,211
    Honolulu, HI
    I can honestly say that the Gen 3 Prius/Prius v have one of the worst rides as far as vibration and handling bumps and rough road surfaces.
    It is a relatively heavy car, due to the traction battery pack and electric motor weight necessary for hybrid operation. Combined with a small car, short wheelbase, you've got a rough ride, unless you put it on a real cushy, soft suspension.
    About the only thing it has going for it is the tall sidewalls on the OEM spec wheels. As mentioned, air it down to the lowest air pressures on the door jamb.
    SM-G781V ?
  8. Air_Boss
    Air_Boss Senior Member
    4,132
    1,151
    New Yawk
    At 55,000 miles, the long wheelbase v Five on aired-up, 17 inch 50 series 225 skins, and original OEM struts rides smoothly, carves curves like it is on rails. Of course it does have the TRD rear bar.
    The light, short wheelbase, buckboard, a fun handful to drive, is the roadster.
