in cabin road noise deadening
Discussion in 'Prius c Accessories and Modifications' started by jz13prius, Feb 20, 2014.
  1. jz13prius
    jz13prius Junior Member
    28
    Hi all
    Was wondering if anyone here has taken out the carpet and added dyno mat or fat mat yet. If so does this make a big difference in road noise? Or very little? My C2 seems pretty loud on the freeway.
    Thanks for the help and info
  2. flotowngtm
    flotowngtm Junior Member
    42
    22
    Someone here has done this on a C. Cant remember who..... Looking for it..
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My son-in-law dynomatted his 2005 Prius under the carpet and in the trunk, but didn't do the doors. I measured about a 5 dBa reduction. Changing the tires can also help.
    DoctorD
  4. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    There are some threads in the audio forum of members who have done this. All have reported improved sound quieting.
  5. jz13prius
    28
    Thanks guys for the info. I'll check the audio section
  6. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    dont forget, extra weight means less MPG. but it shouldnt impact it that much.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    150lbs of dynomat is what the aforementioned user had... I don't think that will affect the MPGs much.
  8. jz13prius
    28
    Thanks for the info. Would you happen to know any threads that have some pics and detailed info on installing front speakers and tweeters?
    Thanks
  9. Ken Scheinker
    Ken Scheinker Junior Member
    Used Dynomat years ago in a Nissan Hardbody. Didn't really help.
    PCSpaceShip likes this.
  10. otbiker
    otbiker New Member
    25
    I know this sounds like a smart nice person answer, but if you enjoy music, upgrade the OEM audio system. I've tired quieting a few econoboxes in my lifetime. Thin materials including carpet, metal, and glass are nearly impossible to get ahead of...
  11. Max Taiwan
    Max Taiwan Active Member
    428
    384
    Taipei
    2018 Prius v wagon
    I found doing the pillar seals and door lower seal helped a bit for road noise. But on highway the engine low hum is there always. If you would like some photos I'll be happy to post some for you
    priustexasbob likes this.
  12. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    yeah that would be great, thanks
  13. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    What it does is complete the seal from the original door seals.
  14. padroo
    padroo Senior Member
    2,763
    2,250
    The road surface is a big factor in road noise. I have one road where they switched to a different grade of blacktop and the noise changes drastically.
  15. Kenichi
    Kenichi Junior Member
    US
    Where'd did you get those seals from?
  16. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    I got them fitted here in another city, but if you want its a easy DIY job. I just have a lot on my plate these days and money was a tool to solve my problems so I paid to have them done. The parts is roughly $80 for the whole vehicle. If you are interested I can have it shipped to you. They have 3M adhesive backing I think and all you need is rubbing alcohol to clean the areas and off you go. They don't interfere with the original seals of the car and no water problems after heavy rain.
  17. Kenichi
    US
    Gotcha, I appreciate your offer. I'll take a raincheck for now! If it was a simple item I would've given it a try, but not a top priority currently for me.
  18. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    Cool no problem. Just shoot me a message when you want.
