In-Dash CD Player
Discussion in 'Gen 2 Prius Audio and Electronics' started by terkar, Jan 13, 2004.
  1. terkar
    terkar New Member
    104
    Hendersonville, NC
    I have the standard single slot plus a port added option 6 in-dash cd changer. Does anyone else have this combination?
    My question is:
    With all 6 filled can I use the single standard slot to play a 7th, :oops: or will it jam?
  2. PriusDreamer
    PriusDreamer Member
    138
    Long Island, NY
    Can you also let me know if this combination comes with the standard speakers or the upgrade?
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The 6 disc changer comes std with the premium system, which has the outboard amp, better speakers, cassette, etc. The port ad-in is for the base system, so most likely he's got the base speakers amplified by the head unit.
    Also note, if you've got the additional CD player, you may not be able to get the XM radio ad-in unless Coastal Dave comes up with a Y adapter or something.
    -Rick
