In Dash Opening...
Discussion in 'Gen 2 Prius Audio and Electronics' started by TroyBurnett, May 8, 2006.
  1. TroyBurnett
    TroyBurnett New Member
    Is the in dash opening below the CD changer in the '06 model, (where you could put CD's, etc.) capable of holding an audio component that would fit into a standard slot?
  2. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    Yep....it's got the smoked glass retractable door covering it, but behind it
    is a pocket. I'm considering adding an EQ there.
  3. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    I used the opening to remove the cover and place an VGA Touch screen monitor. Installation was not too difficult, but it makes a perfect spot for a second screen. The spot is a standard DIN so it makes a nice place for extra mods.
    Yes, I'm nuts about the Prius.
    ---Kent
  4. tmorrowus
    tmorrowus Member
    514
    yes. I installed an alpine head unit there.
