In desperate need of help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nathan_lbc, Oct 18, 2021.
  1. Nathan_lbc
    Nathan_lbc New Member
    long Beach California
    Hello, I have a 2009 Toyota Prius. I was driving about a week ago when my engine started sputtering and eventually stalled out. TROUBLE CODE: P3190 (the car will start up for about ten or so seconds and then the engine stalls out) I went to the Toyota dealership and paid $160 for a diagnostic scan and they recommended that my fuel pump needed to be replaced and they quoted me for $3,000... I got the part myself and installed it and I still had the same problem … I looked online for possible reasons why I am getting the code and a few forums said it could be:
    Air induction system malfunction.
    Defective throttle body
    Improper fuel pressure.
    Defective engine.
    Defective Mass Airflow (MAF) meter.
    Vehicle is out of fuel.
    Defective Engine Coolant Temperature (ECT) sensor.
    Defective crankshaft position sensor.
    Defective camshaft position sensor.
    Defective Engine Control Module (ECM).
    I also replaced the mass air flow sensor, throttle body, and camshaft position sensor… I am going to try to replace the crankshaft position sensor before Calling it Quits and either selling it for junk or trying to take it to someone who specializes in hybrid cars. I feel like I'm beating a dead horse.
    If anyone has any possible solutions please let me know because I'm at the end of my rope throwing money and time at this vehicle.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,923
    880
    Southern California
    That dealership sounds sketchy. $160 for a diagnostic scan and $3000 to replace a fuel pump? The whole process for the scan takes about 5 minutes. I have no idea if that $3000 is reasonable, but it sounds much too high for any kind of fluid pump installation, at least in general. Rock auto has an ~$300 part which looks like a combined tank and pump. That is not an OEM part though, and who knows how much labor is required to swap one.
    Surely there must be an independent mechanic somewhere in your vicinity who works on this model car. Search these forums, or start with the names in this thread and if they are out of range, perhaps they can suggest somebody:
    Los Angeles Mechanic | PriusChat
  3. ChapmanF
    18,668
    Fuel pump may be expensive because of the bladder fuel tank; might require changing the whole tank. Gen 3 has a non-bladded tank and the pump can be replaced on its own.
    It's true, there's a long list of things that can cause reduced engine power. That's always been true of engines. It doesn't really pay to try to just replace all those named parts and see what happens. And it's important to remember that, say, a mass airflow reading doesn't just depend on the MAF sensor ... it depends on the wiring that goes to the sensor ... it depends on the tube where the sensor's mounted being airtight ... and so on.
    Really, with a situation like this, one has to look up how to diagnose a gasoline engine with reduced power, and do that. If there are specific codes from the ECM, they can help point you in a productive direction, but they aren't an answer key in themselves.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    yes, a gen 2 requires replacement of the entire fuel tank/fuel pump as an assembly. I'm impressed that you went and made that purchase and did that installation on your own. That's a lot of work, including all the other various items replaced.
    The 'runs about ten seconds' is more likely the car spinning the engine trying to start it, not actually the engine running.
    An engine needs three things...air, fuel and properly timed ignition. One thing I've found that works well to verify a bad fuel source is to spray some starter fluid into the throttle body as someone else attempts to start the car. What's convenient about a Prius is you can press the power button, and then walk to the front of the car to be the sprayer also since it takes several seconds before the engine starts trying to spin for ignition. If you can keep it running using starter fluid, but the car dies without it, then the fuel system is your likely culprit. If the car won't run, even with starter fluid, then it's more likely something else is bad, like no spark or no airflow into the cylinders.
  5. JC91006
    16,863
    8,617
    Do you have gas in the car? Prius cars that stall like that usually run out of gas
  6. koco
    koco Member
    113
    38
    Las Vegas
    I had that happen after cleaning the throttle body and MAF...some dirt got on the MAF after cleaning the air filter box. Make sure the air filter is not clogged and clean the MAF for starters. Clogged fuel injectors are more likely than a bad fuel pump; I had fuel trim readings of +3.91% before running fuel additive injector cleaners for 2 tankfuls...now down to +0.5%. These tiny motors are finicky about these things.
    Have a look at the spark plugs to see how its running.
    Go for the simple and less expensive things first before replacing major parts.
  7. JC91006
    16,863
    8,617
    If you want to tow it to a shop that sees a lot of Prius cars, you can try the Hybrid Pit in Buena Park. Not too far from you and they would be able to sort the problem out for you
