In Room Wi-Fi at the Hotel
Discussion in 'Fred's House of Pancakes' started by JimN, Jan 16, 2008.
  1. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I don't stay in many hotels but haven't found one with a strong wi-fi signal in the room. My USB adapter works fine in the lobby. This occurs in Days Inn, Quality Inn, Innkeeper, and The Brant(?) (the old Adams Mark in Charlotte, NC). Is it my cheap-o eHome device or is this a common experience?
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I find that the USB adapters are not that great because they use a very small antenna and they are usually under powered. I would only use a USB wifi stick if you could actually see the wifi router. My 802.11b Orinoco Gold card can pick up signals very well. It does even better when I hook up an external antenna to it. I would say if you want to always get the best signal get a good PCMCIA card. They cost a little more but they are worth it. I just picked up a new Orinoco 802.11b/g card for $65 to replace my old Orinoco 802.11b card. I also picked up the Linksys WRT54GL to do some hacking with. :)
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    If you've got a way to continuously watch signal strength as
    you walk around with the laptop, watch it as you walk away
    from the lobby [where at least one of the APs likely is]. Then
    get a friend with a different setup to do the same... not
    all the interfaces have reasonable antennas, i.e. geared for the
    home market where it doesn't have to punch very far..
    _H*
  4. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    I've had varying degrees of success with hotel/motel wi-fi. I don't need to worry about it anymore, though. I got mobile broadband about a year ago. You can't beat the portability, and I'm no longer dependent on someone else's network (other than Sprint's) when I'm traveling.
  5. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I'm not sure Wi-Fi is generally available in individual hotel/motel rooms, so I don't think your usb receiver is a problem. I don't travel often in the US, but my international experience has been that public areas like a lobby, bar or meeting room of a hotel might have free Wi-Fi, but internet service in the individual rooms is wired and cost money.
  6. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Most hotels/motels I stay at now have in-room wireless.
    I've never had good luck with USB adapters.
    If you really want range try something like this:
    Ultimate Range Notebook Kit || Notebook Wifi
    I also ask specifically for a room with a good signal when I make the reservation. They genrally know which ones are better :)
  7. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    My wife's older laptop doesn't have built-in wireless so I bought a USB WiFi stick. Shame on me for going cheap! We live in a small condo and she can't receive a steady signal in the living room from the den where the wireless router is. My work computer with the built-in always has a very strong signal.
  8. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    When we stay in hotels, we always travel with a cable so we can just directly plug in. Sometimes the WiFi works, sometimes it doesn't, but hotels are supposed to have connectors available in the rooms.
    It's just one less source of frustration.
  9. JimN
    7,028
    1,116
    South Jersey
    Thanks all for the advice.
  10. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    Im actually in a Holiday inn epress in Kenosha wis right now and the wi fi is really good. 3rd floor in the room. Only downside is my slingbox is connecting much slower than at home it works and i can see and hear everything, but its a little grainy.
  11. haiku88
    haiku88 New Member
    Sonoma, CA
    If you use a USB extension cable you can move the wifi adapter if reception is a problem, sometimes a foot or so makes a big difference....or if that fails it is easy to build a wifi wok, see http://www.usbwifi.orcon.net.nz/
    I made one from a small Weber BBQ lid and it works great...
  12. patsparks
    10,664
    567
    Adelaide South Australia
    I have a wifi card for my PDA which picks up an excelent signal from one side of my home to the other. You get a better signal strength if you are away from walls especially solid walls like brick.
  13. daniel
    14,487
    1,518
    Spokane, WA
    Some hotels have ethernet plugs in the rooms. Some do not. Hotels are not "supposed to" have anything they don't want to provide. Some have free wifi. Some have free ethernet. Some charge. Some have wifi only in the lobby. Some have it in the room. Some have free wifi in the lobby but charge for internet in the rooms!
    I've had mixed experience with hotel wifi. Sometimes the signal strength is inadequate, sometimes it's fine. Sometimes the wifi is incompatible with my laptop, and at some hotels I've struggled for hours, only to find that they know their wifi is incompatible with many wifi cards.
    I've had better luck with my Nokia N800 than with my laptop, but I've been places where the N800 did not work while other folks' laptops did, even though I had excellent signal strength.
    I've never had any trouble with ethernet, when it's available, but often it's not.
