in the market for a new Prius a v or plug-in??
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by vajratlr, Sep 6, 2012.
  1. vajratlr
    vajratlr Member
    197
    Los Angeles, California
    2013 Prius Plug-in
    My 2010 Prius' lease is about up so need to get another car soon. I driver about 85 miles to and from work everday in hectic socal traffic. So plug-in would be nice because I can get a HOV sticker but obviously it'll cost a bit more than a v. Unless the MPG can offset the increase in cost then it would be a no brainer. Right now, I get about 55mpg out of my current 2010 and it's great. I don't think I'll be able to plug it in at work unless I can plug it in to an wall outlet directly(not too familiar with the plug-in). What MPG do I really get given my drive?
    My main reason for the v is because we have a baby girl now plus our lab. She can barely fit in the back storage area of the Prius. Thoughts???
    Thanks!
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    I've got a 6 year old and no dog. I've owned 3 prius with a PiP currently. If I had another kid or a dog with 1 kid I'd want a v having driven one and rode in one for a bit. Just my opinion.
  3. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    The charging cordset (L1 EVSE) that comes with the Prius Plug-in plugs into a standard 120V outlet, so if you have a regular wall outlet available at work, you can charge it.
  4. vinhboy
    vinhboy Junior Member
    25
    Davis, CA
    I don't think a prius plugin makes sense for a 85 miles commute. You can check out the volt. I hear it can do about 50 miles on the charge, so if you can plug in to a regular outlet at work, you've got yourself an all electric commute. It wouldn't fit your dog though...
  5. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    I heard that the charging cable is $1k, is there a way to secure them while charging in public places?
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I noticed on another thread that the charging cable does not lock when in use. It seems to me that it's quite possible the thing will grow legs someday. So I asked my dealer the price of a replacement.
    Read more: http://priuschat.com/threads/securing-the-charging-cable.105077/#ixzz25jV2kjow
  7. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
    I have two sons and a Sheltland Sheepdog. The v would be great for the baby. The backseat in the v is great plus the middle seat has a lot of room. I put a Costco dog bed in the back of my v and my dog has lots of room.
    Hope this helps.
  8. CharlesH
    2,796
    1,163
    Roseville, CA
    If you are using a 240V charging station, you are using the charging station's power cord and J1772 plug. And if you are using a ChargePoint 120V station, there is a locked box you can put your EVSE in that is locked/unlocked with your ChargePoint card.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    really..........all the ChargePoint stations I've gone to can only hold the plug and cord. there's not enough room for the brick
  10. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    thanks for the input guys! but this thread probably went off on a tangent. I guess as one post stated, 85 mile commute is probably not the best candidate for the plug-in??
  11. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Given your distance and space requirements the v may be the best fit!
    That said, there is a case to be made for the PiP for long commuters particularly if you can find a way to charge during the day. At least with that commute distance you know that you'll always be getting your money's worth out of the battery :)
    If you can only charge at home, you'll offset about 15 miles of your 85 miles/day. At 55mpg, that will cut your fuel use from 1.55 to 1.28 gallons per day (66mpg). Assuming you commute 5 days a week, 48 weeks a year, and gas is $4 that's $1488 (372 gal) vs. $1229 (307 gal) saving $259 (65 gal) per year on gas, but you'd likely pay back about half that in electric costs.
    If you can charge at home and work, now you'll offset 30 miles out of 85/day. At 55mpg now your daily consumption is cut from 1.55 gallons to 1.0 gallons (85 mpg). With the same assumptions annual gas cost goes from $1488 (372 gal) to $960 (240 gal) for a savings of $528/yr (132 gal), but again you'll probably lose half that paying for the electricity.
    Interestingly with a long commute you're really no worse off than someone with a seemingly more "ideal" commute. Either way, if you can only recharge once a day you'll offset 15 miles or 30 miles recharging twice. From a return on investment perspective, the key is basically maximizing the number of times a day you can completely drain and refill the battery. Once you've paid for it, you've got to use it to start earning your money back ;) From that perspective, a commute that's too long for the range of your battery is actually better than a commute that's too short. With a longer commute you'll save just as much gas/money as the "ideal" 15-30 miler, your mpg numbers just won't sound as sexy. With a commute that's too short, every time you either skip an opportunity to recharge or recharge a less than empty battery you're throwing away some of that potential gasoline offset.
    With current prices its unlikely that a PHEV will pay back its initial cost over its life, but you can at least try to get back as much as you can. A longer range PHEV or even EV would get you more gas offset/savings, but the bigger battery usually cost more and may have other compromises (vehicle size (Volt), range limitations (Leaf), etc.) If you are feeling adventurous, another avenue you could explore would be to look for a used Prius (or a new V!) and put something like the 10kW Plug-in Supply conversion kit in it. You'd get a lot more gas offset (40-50 miles per charge?) and probably come out cheaper than a new PiP, but I don't think conversions get the CA carpool sticker.
    Ultimately you just have to weight the cost difference, value of the carpool sticker, value of the extra room, value of using less gasoline, etc, etc and decide what makes sense for you :)
    Good Luck!
    Rob
    vajratlr likes this.
  12. bisco
    51,155
    imo you should decide between hov sticker or extra room. you won't save enough on gas to make a big difference. although there is one thing not taken into consideration here, the pure thrill of driving all electric, especially if you do any evening or weekend local driving/errands. is the extra time with your family worth cramming your daughter and dog into the back? all the best with your decision and let us know what you buy and how it works out for you.
    DianneWhitmire likes this.
  13. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    Appreciate your extensive input, helps a ton! I can probably charge at work for free so 30 miles a day minus the electricity at home means I save about 27.5 miles aday. So my 85 miles a day cuts down to 57.5. The money savings definitely dosen't offset the increase in lease cost. But with 2 years of HOV access, that's more tempting than anything else. I spend on average 3 hours a day on the road. I can probably cut down the time to 2:15 which is huge for me! On the other hand, V is bigger. I assume more headroom so easier to load/unload the baby from car seat. More room for the dog in the back which is definitely another plus. However, less MPG...
    decision, decision!!
  14. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    The cord can lock. I have also just plugged in and driven atop the cord too. No one can get it that way. ;)
  15. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    Hi Dianne,
    What kinda lease programs do you currently offer for the PiP base and the V 3? Thanks!
  16. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    The difference isn't just the 45 minutes less driving a day, it's the 2:15 of less hassle free driving. I take the LIE HOV lane and it's so much less stress driving in the HOV lane rather than the regular lanes. Besides, you can spend 45 minutes more a day with your baby girl. Enjoy these times, because they grow up fast.
    Another thing to take into account is that the PiP will get you better gas mileage when in the HV mode than a regular Prius. So, that will add to your cost savings.
    BTW - what is your other car? You will put on minimal miles when you have a full load, compared to your daily commute.
  17. DianneWhitmire
    4,062
    1,123
    64
    Laguna Niguel, CA
    I am sure if you check the PlugIN section, you'll find them there well published. Just updated today.
  18. DianneWhitmire
    4,062
    1,123
    64
    Laguna Niguel, CA
    It costs me about .19 an hour to plug in at home. That's approx 60 cents a day, so
    $18. a month.
  19. ultraturtle
    108
    81
    Peachtree City, GA
    You might also consider the incredible luck of timing. PiPs are currently being sold at unbelievable discounts off MSRP, largely because gas is incredibly cheap at ~$4/gal.
    Do you want to gamble that PiPs or gas will ever again be this inexpensive?
    Financialy speaking, I gambled and lost by purchasing at MSRP minus $500 back in November. You can do much, much better now.
  20. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    we have a 4 door Honda Accord which my wife drives. It's smaller than the Prius plus no back area for the dog.
    what's a LIE HOV lane?
