Incoming Bluetooth calls causing Treo650 to reboot?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Gaelyn37, Dec 10, 2007.
  1. Gaelyn37
    Gaelyn37 Gaelyn
    McMinnville, OR
    Everytime I receive an incoming call via Bluetooth over my Treo650, it causes my Treo to reboot. I thereby loose the incoming call. I can use voice commands and Bluetooth to place outgoing calls just fine. If I use a Bluetooth headset out side of range of my Prius, my Treo receives the call with no problem. It seems that the Prius Bluetooth is causing the problem. I have the updated software for the Treo650, etc. Any ideas? Thanks.
  2. dumas
    dumas Junior Member
    44
    NC
    My Treo 650 doesn't do that. On the other hand, plenty of other things make it reboot :(. I've had one since they came out and really like it, but I've just gotten resigned to it being a little flaky.
  3. Ken S
    Ken S Member
    191
    Pittsfield, MA
    Never had that happen with my Treo 650 or 755 either. You may want to look at some of the 3rd party software you have installed to see if there's a conflict.
