Increase screen wash capacity
Discussion in 'Gen 2 Prius Main Forum' started by Britprius, Jul 21, 2011.
  1. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    I have noticed that when filling up the screen wash on gen2 the container cannot be filled to the top because of an air lock in top. To gain a useful increase in capacity if you pierce a small holes, (not drill) with a sharp pointed tool or soldering iron in the top of the baffles near the top of the filler neck the container can be filled to the top, adding about one pint to the capacity. The holes should not be drilled because plastic particles will end up in the container risking damage to the pump or blockages.
  2. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    Wouldn't increasing the duration between fillups actually increase the liklihood of running out? It would be easier to forget.
  3. Britprius
    5,194
    1,918
    I do a lot of miles 80,000 in three years and find with our UK weather on long motorway runs it all to easy to run out of screen wash and that is an offence here.
  4. Mendel Leisk
    40,575
    Just an idle thought: post-mod are you filling up into the neck region, and might there be splices in the neck that aren't watertight? I've no idea if that's the case, just speculating that the air lock might be purposeful.
  5. Britprius
    5,194
    1,918
    The container is a one piece plastic moulding no splices and a tight fitting lid. The internal baffles could just be to make the container more ridged.
  6. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I believe that air space is to allow for expansion of the fluid in hot weather conditions. I would leave it as designed.
  7. Britprius
    5,194
    1,918
    Water does not expand that much with normal temp changes and the lid has a breather hole in it, further you still cannot fill higher than the point at witch you make the holes.
  8. Patrick Wong
    18,200
    6,492
    I believe that air space is to allow for the fluid freezing and expanding, if the owner does not use washer fluid rated to 0 degrees F.
  9. Britprius
    5,194
    1,918
    The washer bottle may be different in the US version, In the UK version it is mounted by the bonnet (sorry hud) hinge to the left of the ICE in front of your passenger our driver.
  10. Patrick Wong
    18,200
    6,492
    Same location in the North American Prius. When facing the engine compartment, the washer bottle is on the left (or passenger-side) fender, adjacent to the engine.
  11. Britprius
    5,194
    1,918
    Washer fluid rated at 0 degrees F would be solid here over the past few winters.
  12. Britprius
    5,194
    1,918
    Forgive my ignorance of US terminology is a fender what we call a bumper, if so is your bottle mounted in the fender ours is mounted just below the screen.
  13. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    No one here would put in stuff only good to 0 F... the standard stuff is good to about - 40 F. Even in the summer we put that stuff in since we may not empty it before winter. And no, it doesn't get that cold around here, but even at freezing when driving down the road and you squirt the windshield the stuff will freeze due to some fraction evapourating and the rest freezing. Not very safe.
    It's nice to talk about this when we have a heat wave going.
  14. bisco
    51,141
    i don't remember not being able to fill it all the way.
  15. Patrick Wong
    18,200
    6,492
    A fender is the sheet metal part that covers a tire. I'm sure that the washer fluid container is mounted in the same location.
    I live in an area where the summer high temps are around 110 degrees F while the winter low temps are generally above 32 degrees F, so windshield washer fluid rated to 0 degrees F is as low as I've personally seen...
  16. Britprius
    5,194
    1,918
    Thanks for the education re fender our mud garde. Not sure about the 110degree part of your weather but I am envious, our temperatures this year have gone from -23.5degrees C to 30degrees C (-10F/86F).
  17. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    American Fender = Quarter panel. (The metal between the headlight and the passenger/driver door)
  18. Britprius
    5,194
    1,918
    UK quarter panel = metal between rear door and tail lamp, the metal between headlight and front door = wing
  19. bisco
    51,141
    cool. how did we get so mixed up in 200+ years?
  20. brownsnoutuk
    185
    119
    Shepherd, TX
    there are front and rear quarter panels. brownsnout(UK)
