Increasing Cargo Storage Area
Discussion in 'Gen 4 Prius Accessories and Modifications' started by 90ford, Mar 2, 2016.
  1. 90ford
    90ford Junior Member
    San Jose, CA
    Three Touring
    There is no nice storage pan under the cargo floor on the 2016 like I have on my 2006. I was thinking of cutting the foam bump off of the bottom of the foam spare tire cover so that I can store a backpack under the floor on top of the spare tire. Has anyone tried that? Ant better ideas? I need to store a backpack and extra water in case of an earthquake.
    PriusOffroad, kenoarto and bisco like this.
    49,490
    i would just take all the foam out and line the bottom with soundproofing.
    PriusOffroad and 90ford like this.
  3. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    So basically your under floor storage is now included in one big combined open space, right? So the issue just is lack of hiding spaces. Of course if you can find a nook or cranny in the spare that's good. I calculated the spare takes about 1.5-ft3 but maybe up to half that is "usable" space in the wheel.
    PriusOffroad likes this.
  4. 90ford
    San Jose, CA
    Three Touring
    I think that the thick foam slab may be needed as a support for the floor in the cargo area.
  5. 90ford
    San Jose, CA
    Three Touring
    I am just trying to make better use of the space between the spare tire wheel and the bottom of the foam slab. Toyota just filled it with foam but I want to store things there. Things that need to have but not use except in an emergency.
  6. bisco
    49,490
    have you looked at the thread where the owner re did all the foam?
  7. 90ford
    San Jose, CA
    Three Touring
    No I have not. How do I find it?
  8. bisco
    49,490
    look in the gen 4 threads. it was someone who wanted to add a spare. i'll look as well.
    90ford likes this.
  9. bisco
    49,490
    try 'compact spare for two eco' by krousdb, in this forum, acc. and mods.
    90ford likes this.
  10. BigRed
    BigRed Junior Member
    That foam block seems structural - it is too bad to lose all that space
  11. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    I would add that in at least some models it also functions to create a sort of "ducting" for the battery ventilation.
