Indexing a large USB drive
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Toyo_Tom, Feb 11, 2020.
  1. Toyo_Tom
    Toyo_Tom Junior Member
    Ohio
    2020 Prius Prime
    I recently got a USB hard drive large enough to hold my entire music library, which is substantial, coming in just short of the car's 9999 total track limit. I have had it for a few weeks now and still have not managed to get the system to index the entire drive. The drive itself is reasonably fast, and when my computer was transferring to it, it seemed to move along at a nice pace so I don't think that drive access speed is an issue. The problem is that I prefer to just set it to random play and forget it, but based on experience with a much smaller drive that I used previously, until it indexes fully there is a significant delay when moving from track to track in random play unless I manually hit the "next" button.
    I am wondering if anyone knows how the indexing works. It seems like it should have had time to get it done by now, but I am thinking that maybe it does not retain its progress when I shut it off and I am starting off back at square one every time I start up. If this is the case then it would seem that my only choice is to either leave the car "on" in the garage for a long time (which seems wasteful and I don't really want to do) or to do as I read in another thread and put it in with only part of my library on it, let it index, and keep adding files to it and letting it re-index until I get it all on there.
    The library is probably 80-90% tracks ripped from my CD collection, which I store as WMA Lossless, so the files are quite large. The rest are high bit-rate MP3s that I have purchased primarily from Amazon. I don't know if the size of my WMA files is an issue; it doesn't seem like it would be since I would think that it is only reading the tags encoded at the beginning of the files rather than the entire tracks.
    So before I decide what to do, I was wondering if anyone knew for sure how it actually does work. Am I right that it has to be done all in one session, and if so, is adding files incrementally as I mentioned the way to go? Or will it eventually get there if I am patient enough? I hope someone has experience or inside knowledge that can help me out. Thanks in advance for any assistance.
  2. Toyo_Tom
    Ohio
    2020 Prius Prime
    A follow-up with a new issue: I ended up just going ahead with breaking up the job and only transferring part of the files at a time. I found that if I broke it up into three batches of 3000+ tracks that it would index the new music in about four or five minutes. So obviously something is broken when it comes to dealing with large numbers of files, because from this experience, it follows that it should have been able to index the whole 9900+ tracks in about fifteen minutes, but instead goes on forever. I had at least a couple of two-hour continuous round trips and it never completed in any of them.
    But this post is actually about a new issue. Even once the entire drive is indexed (which I can tell because it will start to display track numbers), every time I shut off the car, when I start it back up again, it will play the song it had queued up, but it apparently has to re-scan the drive, and during this time, the player only sees the song that was playing when it started, and it acts like that is the only track on there. If that song finishes before the drive is re-scanned, it will repeat the same song again. If I try to move to a different track with the selection buttons, I get a message to the effect of: "Please wait while your library is re-scanned." This seems to take just under five minutes, so unless I am lucky enough to have a long song selected to start playing, my choice is to either listen to that song again or to pause it until everything is ready again.
    It just baffles me why this is so hard. My mom's Ford Escape can play from a collection this large with no issues whatsoever. If it is really going to be this big of a deal, they should have just set the total file limit to 5,000 or whatever they could handle. I suppose I could go back to playing from my music player via the aux cable, but I prefer not to sacrifice the sound quality and the ability to control directly from the touchscreen.
  3. mike wood
    mike wood New Member
    North Carolina
    2020 Prius Prime
    I have a new Prius Prime Limited (2020) with the same problem. I have about 1800 songs on a 16GB usb and the Prius will not index all of the songs and the "random" play selection does not work properly. If I browse the song list there are many songs that don't appear that are on the usb. I can take the same usb and play it flawlessly on my Ford Edge. I have talked to Toyota directly and they were no help at all. I have tried several dealerships including the one I bought it from and they don't have a clue. I cannot see how a multi-billion $$ company can fail to engineer such a simple task. Usually we listen to music on usb about 70% of the time but it is so annoying now we listed to the free Sirus most of the time. I have tried everything I know. Does Toyota monitor this site and provide any insight?
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    First world problems...….:)
  5. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    I have no problems at all using USB drives on mine. I have about 12 30GB USB flash drives, each mostly full with music, either as mp3 or WMA Lossless. So far, everything plays fine. It can take a few minutes to be able to access the drive after plugging in, but once indexed, no issues at all.
  6. Toyo_Tom
    Ohio
    2020 Prius Prime
    How many songs do these drives contain? I find that it can index up to somewhere around 3,000 without an issue.
  7. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    It varies, I have them saved in various resolutions ranging from 320kbps to lossless, and many songs are quite long. Maybe somewhere around 2500-3000?
  8. Toyo_Tom
    Ohio
    2020 Prius Prime
    Your issue seems to be even more severe than mine. 1,800 should not be an issue and should index in just a few minutes. And I never really seemed to have an issue with missing songs once everything was indexed. Of course, I don't know this for sure, because there is no way to check through 9,000+ songs to see if some are missing, but judging by the numbers it displays, they all seem to be there--songs near the end of the sort order show as track #9___ (whatever the actual number would be, but they are in the 9,000 range).
    As to whether Toyota monitors this site, I would be surprised if they did. Some contributors have reported talking to "insiders" about issues raised here, but there was no indication that they were directly monitoring the thread. But anyway, between issues like this and the dismal app representation, I agree that it is ridiculous that a car designed around technology would be lacking in so many basic areas. But they do at least have the engineering of the car itself down pretty well.
  9. mike wood
    North Carolina
    2020 Prius Prime
    After 6 wks of working on it I still cannot get my 16GB, 1800 songs to play on my P Prime. Reads maybe half the song titles. Have talked to Toyota Corp and the dealer who sold me the car with no help. Toyota Corp said maybe a software refresh would help and the local dealer said some USB makes were not compatible. Both are BS. Changed brands of usb and even cut the number of songs in half and nothing helps. I will repeat what I have said in the past - I can take the usb out of my Prius and plug it into my Ford Edge and it plays without a hitch. Toyota has some basic problem and it does not appear it cares about customer service about this issue.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    They may have told you the truth......and given you the right answer, almost.
    It is entirely possible that a "drive" that big just isn't compatible with the Toyota system.
    In general, many "players" are limited to 8 GIG.
    My bet is that if you split your library onto two 8 Gig drives you won't have a problem.
    Or you can keep wasting your time for another 6 weeks and getting frustrated about it.
    One of those options solves the problem and the other doesn't.
    Your choice.
  11. mike wood
    North Carolina
    2020 Prius Prime
    Since others on this chat who have the same model report no problem it does not appear that the usb size is causing the difficulty. Plus what auto manufacturer in 2020 would limit a popular audio option to 8 gb? Does not make sense.
  12. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    I'm using an almost full 64GB thumb drive in my Prime, no problems. The folders are organized by artist and album subtier to that.
  13. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    On my 2017 Prime Premium, I was also using a 64GB USB drive without a problem. I also use folders to organize files by artist and album. I never counted, but I think each folder contained less than 256 which I believe is the limit imposed by the system. The biggest problem I had was not the indexing large USB drive, but the inability to scroll down or up a large number of folders I had in the drive while driving. I probably have well over 300 folders, and the "safety" feature of the system allows me to scroll only 20 or so of the folder while the car is in the drive. How stupid is that I have to stop the car and put in the park to just change the folder from A to Z.
    Now, I have 2020 Prime LE with a smaller display. I have not played with the USB drive much, so I don't know this limitation exists on my current PRIME.
  14. MikeDee
    1,572
    596
    I would think there should be software out there that could automatically sort your usb drive into folders by artist and album. That should take care of any file limitation limits.
  15. Salamander_King
    11,009
    8,935
    New England
    Is your comment directed to me or to OP? I have every file in folders already. I did it all manually, but there is an easy software to do just that, I am all for it.
  16. MikeDee
    1,572
    596
    The OP. MusicBrainz Picard, can do it, according to a YouTube video I saw.
    Salamander_King likes this.
  17. Salamander_King
    11,009
    8,935
    New England
    I just noticed today something new in my 2020 PRIME LE USB music player. On my Prime LE, songs will continue to play multiple folders. Once all the songs finished playing, it plays the next folder files automatically. This was not the case in my previous 2017 Prime Premium. Once all the songs were played in a folder, it will repeat the same folder again, but to go to the next or another folder, I had to select that folder from the screen. This may or may not apply to other 2020 PRIME models with 11.6 inch display, and it may have been this way in earlier 2017-2019 Prius Prime Plus model with a smaller 7" display. But it is a new feature for me and is much welcomed.
