Indicated MPG vs calculate MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by asteros, Oct 13, 2016.
  1. asteros
    asteros New Member
    26
    Oregon
    My little contribution to the forum:
    Looks like the indicated MPG is def little more optimistic than the reality. Have only 1 data point so far:
    The trip indicated MPG was 56.1, whereas the manual calculation (based on distance and real gas consumption) gave 52, which is almost 8% over estimation.
    52 is still amazing and it's mostly short commutes and a few highway trips.
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    Poor Hyundai had to pay back customers for MPG claims that turned out to be false. My son received a $500 check from Hyundai for mileage compensation. Toyota better watch their fuel mileage claims because they are off more than claims made by the Korean company. So much so, that it's beyond fudging a little.
  3. grnd0
    grnd0 Member
    42
    26
    . Prius is rated 50 mpg and he got better so what are you saying?
  4. BZzap!
    1,607
    877
    Point taken. Speedometer sucks though
  5. asteros
    asteros New Member
    26
    Oregon
    Yeah. So it's better. Also, isn't MPG quotes provided or certified by EPA?
  6. grnd0
    grnd0 Member
    42
    26
    The dash mpg is maybe 1-2 mpg on the high side. Hand calculating is very hard because it is very difficult to put the same amount of gas in every time. Car only holds 11 gallons so if you don't fill exactly the same every time it will throw mileage numbers off.
    Redpoint5 and asteros like this.
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Perhaps using a little math would be easier. miles driven (odometer readings)/gas for fill up = mpg
  8. Mendel Leisk
    38,644
    Exaggerating the displayed mpg and exaggerating the claimed mpg are two different things. Both frustrating, but it's the latter that leads to court challenges.
    With about 120 fill ups with an overall positive error of around 7.5% (it varies, as high 9%, low as 5%) I'd agree with you. All I can think: Toyota is doing this intentionally, and pushed just as far as they figure credulity will swallow.
    There's a few naysayers that argue "hey, it's the pumps, inaccuracy, and so on". But I don't think that washes: neutral inaccuracies would fall on either side; a consistent, relentless, positive bias is inexcusable.
    prev93 and asteros like this.
  9. eman08
    eman08 Active Member
    360
    192
    US
    I'm the complete opposite. My 2nd Prius stays consistently around 51 MPGs but by hand it's actually 58 MPGs going 351 miles on only 6 gallons.
    asteros likes this.
  10. Mendel Leisk
    38,644
    ^ That is strange.
  11. ETC(SS)
    6,540
    Congratulations!
    That means that you're measuring accurately. :)
  12. Rebound
    Rebound Senior Member
    3,964
    2,612
    Portland, OR
    It's easy to calculate your MPG:
    Fill tank
    Reset Trip Odometer
    At next fillup:
    Fill tank
    Note gallons added
    Note mileage on trip odo
    Miles divided by gallons added = MPG
  13. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    I posted this on another thread, regarding displayed MPG:
    "There are numerous inaccuracies; for starters, many vehicles (including the Prius) report fuel consumption on the instrument panel display based on MAF sensor and oxygen sensor (A/F ratio) readings, not injector readings, even though injector readings correlate better with actual fuel used (although, even that is inaccurate--Toyota vehicles sum ten injector pulses per cylinder and then transmit that information to the ECU, which then averages it). A 2014 fleet study by HEM Data found an average 2.8% discrepancy between displayed and measured fuel economy."
    That 2.8% discrepancy is among 4-, 6-, and 8-cylinder passenger cars from all manufacturers, BTW. Toyota isn't doing anything nefarious; it's just an artifact of how the information displayed is obtained, and it's endemic to nearly all cars with an MPG display.
  14. fuzzy1
    10,149
    Hyundai (and Kia?) got in trouble for reporting false EPA test figures. Do you have information suggesting Toyota also reported false EPA figures?
    The MPG numbers displayed on the dashboard are not regulated by any federal standards, and are not used in any of the CAFE / EPA testing.
  15. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    My display averages 2 MPG optimistic. It's important for me to know average MPG accurately since I tend to run the fuel tank very low. I multiply the average MPG by 10 (the PiP has about a 10.2 gallon usable capacity) to estimate my maximum range to a high degree of accuracy.
    No and no. MPG ratings are supplied by the manufacturer and certified by no one.
    The EPA tests about 10% of vehicles to keep the manufacturers worried. Apparently Hyundai wasn't worried enough.
    asteros likes this.
  16. briank
    briank Solar Powered
    51
    Massachusetts
    Since the car has been new, the computer consistently reports 5% higher than reality no matter the MPG I'm getting or time of year. Based on the number of people with a similar experience with Gen3 Prii, it seems Toyota intentionally tuned it to the high side of acceptable.
  17. Redpoint5
    1,026
    508
    Portland, OR
    The annoying thing about that is that range can easily be calculated in the PiP since the fuel tank is 10 gallons. You simply tack on a 0 to the cumulative MPG display, and that is your range. If the MPG shows 50, then your range is 500 miles. A 5% overestimate will have you running out of fuel 5% sooner than your calculated range.
    I understand why Toyota would be optomistic with the MPG, but it can mess people up who rely on the accuracy.
