Indicator Fogging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by *Goldfinger*, Feb 17, 2015.
  1. *Goldfinger*
    *Goldfinger* Junior Member
    Sheffield, England
    Any tips on cleaning up front indicator/headlamp glass, mine getting a little foggy looking around the indicators. It seems to be on the outside of the glass (is it glass). Was thinking of trying normal car polish but don't want to make it worse.
    Bruce Warner likes this.
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
  3. *Goldfinger*
    Sheffield, England
    Thanks hchu1, interesting clip.
    Was wondering if there was anything a little less drastic, as it's only very light fogging.
  4. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    You could do this two-step with what you might already have in your garage.
    *Goldfinger* likes this.
  5. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Try warming the lens first in case it is condensation inside the lamp "not unknown with Prius headlamps".
    If it's outside Brasso works very well with a little elbow grease as does Tcut. Finish with a good quality car polish with a UV protector in it.
    It's plastic not glass.
    John Britprius)
    #5 Britprius, Feb 18, 2015
  6. *Goldfinger*
    Sheffield, England
    Thanks hchu1, another good clip.
    As usual, excellent advice from John Britprius, thanks :)
  7. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I use Novus:
    NOVUS Plastic Polish
    #2 clears up the plastic and #1 cleans it. As others said, follow up with a good wax.
    JeffD
