indicator lights
Discussion in 'Gen 2 Prius Fuel Economy' started by solobristol, Oct 21, 2005.
  1. solobristol
    solobristol New Member
    When I press the recirculation a/c button, it remains lit on the dashboard display even when the climate control system is "off" ? is this what other people are experiencing?
  2. GeekyDragon
    GeekyDragon New Member
    93
    Santa Cruz, CA
    Yes.
    My theory: When recirc is off air will naturally blow in especially when your driving. Some people like this (me), thus, Toyota wants you to be aware of the status even when climate control is off.
    --GD
  3. jeromep
    jeromep Member
    827
    Eastern Washington State
    It makes sense that it would indicate that recirc was on even when A/C is off because it is a physical condition of the car, in that the air inlet baffle is closed and an inside air intake baffle is opened.
  4. Tideland Prius
    16,155
    That's normal. Even with the system off, air can still flow through the vents so if you want to completely shut off outside air even with the system off, you press recirc.
  5. FourOhFour
    FourOhFour Member
    127
    Earth
    On mine, the A/C AUTO light remains on as long as you leave the climate control system on auto, regardless of if the A/C compressor is on or not. It goes off if you turn the fan off, or manually set the fan speed, or manually choose vents.
    I think it's the most misnamed light on the Prius. It should be something like "CLIMATE AUTO". (And almost any time "AIR CONDITIONER" is used on screen it should use "CLIMATE CONTROL" instead.)
    To turn the climate control off completely, bring up the climate screen and press the (fan icon) OFF button. As has been pointed out, you'll still get some outside air if recirc was off when you turned climate off.
