Inferior Prius tires?
Discussion in 'Gen 2 Prius Main Forum' started by John Moss, Apr 22, 2008.
  1. Yes, they wore out soon after I purchased the car.
    8.3%
  2. No, they have lasted about as long as tires on any other car I have had.
    83.3%
  3. Somewhat, but I replaced them with a higher grade of tire.
    8.3%
  4. Yes, but Toyota replaced them free of charge for me.
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. John Moss
    John Moss New Member
    Nampa, ID
    Is there some kind of a problem with the quality of tires that Toyota includes on a Prius that they seem to wear out so soon from what so many are reporting?
    Does a person need to go to a tire dealer and upgrade shortly after purchase?
    Does Toyota need to step up to the plate and furnish higher quality tires with the vehicle?
    Not sure why such a light vehicle would wear down tires so much.
    Please explain and advise.
    May be purchasing a Prius within 30-60 days.
  2. john1701a
    john1701a Prius Guru
    12,826
    5,306
    58
    Those choices listed are way too limited. The comments are extremely vague. In fact, there's no detail at all. And the reference to weight is just plain wrong. No need requirement or basis of comparison was provided either.
    You get an adequate tire.
    It works fine for many.
    What ratings do you want... Treadwear? Traction? Temperature?
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I agree with John but I voted anyway. I have driven on the stock tires for over 30k miles with minimal wear and in all kinds of weather except DEEP snow and never had a problem with them. True they are not as good in terms of handling or traction as a high performance tire but most factory equipped tires rarely are. :)
    I lived in Ontario, OR. when I was young and if it still dumps snow pretty hard in the winter then you may want to invest in a set of snow tires. Other than that the stock tires are fine if you keep them aired up properly.
  4. richard schumacher
    7,665
    1,047
    United States
    Ehh, what's the big deal? Even if they do wear out after 20,000 miles, you still got 20,000 miles of use out of them.
