'Info' button stopped working.
Discussion in 'Gen 2 Prius Main Forum' started by George W, Feb 3, 2019.
  1. George W
    George W Senior Member
    911
    514
    San Antonio
    My Info button became intermittent starting 2 days ago. Now it won't toggle at all, still feels the same when pressed.
    Car has 141K miles. Any ideas? Thanks.
  2. prius_deep
    prius_deep Member
    105
    38
    road
  3. George W
    911
    514
    San Antonio
    Info button on the steering console...
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Bad clock spring?
  5. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    That would be my guess too. Any other buttons not working? Can you change the screen by using the touch screen?
  6. George W
    911
    514
    San Antonio
    Yes, touch screen is normal. I tried a quick shot of Dust-Off around the button, didn't help.
  7. Skibob
    2,912
    1,502
    Northern California
    How about all the other buttons on the wheel? Try them all and let us know.
  8. George W
    911
    514
    San Antonio
    At this point in time, the info button is the only steering wheel button which has become inoperative
  9. daisy555
    daisy555 Senior Member
    1,673
    693
    CT
    Did you find a solution to the info button not working? Mine just stopped working a few days ago. : (
  10. George W
    911
    514
    San Antonio
    The only solution is one I am too chicken to try. The Clockspring is the recommended fix, but since it involves disconnecting/reconnecting the airbag I've decided I can live with one non-working button.
    PriusFruit likes this.
  11. VFerdman
    VFerdman Senior Member
    1,185
    1,212
    Western Massachusetts
    It's most likely the clock spring and more buttons will be failing in time. If you can live with it for now, do so, otherwise, replace the clock spring. It is not difficult, not dangerous (despite the air bag, don't fear the ripper) and does not have to be expensive. I have replaced on on my 2006 Toyota Matrix and used a cheapo $9 ebay wonder. It's been 6 months so far and no problems. The process is not difficult and safe. Just disconnect the 12V battery and wait a few minutes. Then the air bag is safe to work with.
    George W likes this.
  12. ChapmanF
    17,340
    The airbag system has a lot of features built in to increase the safety of handling it ... such as connectors that automatically short across the squib when unplugged, to make it less susceptible to static charges. Still, it never stops being an explosive device to be handled with respect. One tip in the manual that not everyone thinks of: when you set it aside, out of the way, set it down bag up, metal inflator down. That way, even in the unlikely case of an accidental deployment, the bag just blows out. (Needless to say, don't set anything on top of it.) Set it down the other way and the same accident launches the metal canister through the air.
    Nine dollars for a spiral cable, after you subtract the cost of shipping it over from China, leaves scarcely anything to cover materials or workmanship. I've never seen a careful side-by-side photo dissection of one of those compared to an original-equipment one, but I'd be surprised if they turned out identical. For something that doesn't get replaced often in the life of a car, I might bite the bullet on an OE one. My dealer sometimes discounts parts a bit if I ask nicely.
    VFerdman likes this.
