Info Button Stopped Working
Discussion in 'Gen 2 Prius Main Forum' started by Go Cards STL, Aug 31, 2011.
  1. Go Cards STL
    Go Cards STL New Member
    St. Louis
    I have an 06' Package 7...with GPS, Bluetooth, etc on the steering wheel.
    The last couple of days I have noticed that when I press the "info" button on the steering wheel, the gas mileage/consumption screen does not show up anymore.
    To get to that screen, I have to hit the 'info' button on the actual screen (not on the steering wheel).
    I don't remember really messing with any of the settings - and all of my other buttons are working on my steering wheel.
    Any Ideas? Did I press something I shouldn't have? :confused::confused:
    Thanks!
  2. EffinRed
    EffinRed Junior Member
    32
    Boston, MA
    Maybe the rocker switch on the wheel is worn out.
  3. Tideland Prius
    16,157
    ^ that's the first thing that came to mind. There's no settings for the steering wheel buttons AFAIK.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It is also possible that the spiral cable is starting to fail. Are all of the other steering wheel buttons working?
    Tom
  5. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    It's probably the spiral cable as it has happened in my 2004 Prius. The defroster buttons also are not working. If I steer hard left or right, the buttons will function. Anyone know the average cost to get this repaired at the dealer?
  6. solidsnake_ala
    solidsnake_ala New Member
    jordan
    i have the same as your car 2006 ... and i have exactly the same problem ... all the buttons work . but the info button does not .... so i want to know if you solved your problem or not please
  7. JoySS
    JoySS Junior Member
    26
    Colorado
    I also have the same problem, same year, same model! I signed up for this site just to figure this out and came across this forum after doing a search. Did you guys figure this out? I only noticed mine stopped working within the past year im guessing. Wonder if the dealership has seen this problem often?
  8. JoySS
    JoySS Junior Member
    26
    Colorado
  9. JoySS
    JoySS Junior Member
    26
    Colorado
    i have the same issue, info button and defrost buttons do not work, but all others do. Could this still be a spiral cable failing as you suggest, or something else?
  10. bisco
    49,500
    if the buttons are on the steering wheel, yes.
  11. JoySS
    JoySS Junior Member
    26
    Colorado
    Also wondering if something could have gotten unplugged when they did the steering shaft recal/replacement? I just took off base cover of steering wheel to see if I could see any plugs or wires, but could not access.
  12. bisco
    49,500
    possible i guess. be careful of the airbag, it can be dangerous.
