Information screen Oil changes
Discussion in 'Gen 3 Prius Main Forum' started by IABoy987, May 14, 2014.
  1. IABoy987
    IABoy987 Member
    184
    76
    Iowa
    2018 Prius Prime
    My 2011 Prius information display started showing oil change logo several weeks ago then disappears. Then today it stayed on permanently. I referred to the manual and found how to reset it, no problem. What I am curious is how often it will pop up ie every 3K miles like my old 2006 model? The dealer has put in synthetic oil good for 10K miles. At present, I am at 21+K miles when the logo popped up. The window sticker says I should change it in October or 26K miles.
    This car has the nav with sat radio package (whatever its package number is) and I did a memory erase to erase all previous owner data. I then pulled up the maintenance screen for oil and it had blank entries, so the information display pop up wasn't coming from there, thus I assume the oil change is "hard coded" into the nav package software.
    Just curious if there is way to change mileage intervals and any other tidbits about this package.
