Infotainment Knob Location
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by AgentPTFC, Apr 15, 2024.
  1. AgentPTFC
    AgentPTFC New Member
    2024 Prius Prime
    XSE Premium
    All of my information tells me the knob is on the right side. I test drove a Prime a few weeks ago and the knob was on the left side. Did I stumble on something not common?
  2. Beach Dweller
    Beach Dweller Junior Member
    46
    28
    The Beach
    2024 Prius Prime
    XSE Premium
    Depends on the size of the display.
    The 8” knob is on the left.
    The 12” knob is on the right.
  3. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    The 12" screen on the right hand side is primarily because Toyota did not "design" it for US drivers.
    Toyota Camry 2025, the 12 " display has its knob on the left hand side. So, the next refresh of Prius will probably see an update/correction.
  4. Hammersmith
    Hammersmith Senior Member
    1,305
    1,330
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Not true. The knob on the 12.3" screen is always on the passenger side with the Prius, no matter if it's a RHD or LHD setup.
    AndersOne likes this.
  5. Hammersmith
    1,305
    1,330
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is correct.
    (unless you live in a right-hand drive country where everything is reversed - but that doesn't apply to the OP)
  6. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    Interesting. Let me ask my friend in Tokyo again.
    [update] Yes. you are correct. - even the one in Japan is on the passenger side for Prius. Only Camry is at the driver side.
  7. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    That is bizarre… why? Seems unergonomic.
  8. Hammersmith
    1,305
    1,330
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is only a guess, but I wonder if Toyota thought it would be helpful for the passenger to have easy access to the volume control? The driver has control from the steering wheel, so maybe they thought they might as well move the knob so a second person would have easy access.
    Or it's because they wanted to move the screen as close to the driver as possible for ergonomics, and that didn't leave room for the physical knob. But the 8" screen uses the same housing, so there's lots of room to put the knob wherever.
    Just some guesses.
    Louis19 likes this.
  9. MIkeDr
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    and the ux300h Lexus uses the same screen, but the knob is closer to the driver…
  10. artieb
    artieb Junior Member
    70
    medford ma.
    2024 Prius
    Limited AWD-e
    How could they miss this for US cars the knob is far away enough to be almost useless a PIA if that’s the flaw maybe not a flaw
    It is convenient for passengers but volume and muting for driver could be way better
    Now that I have lived with the car for three months and 3000 miles I find the infotainment system, poor to fair
    Love the power it’s a point and shoot car now in city driving peppy acceleration
    Downside is that NVH of motor is still coarse when you push it wish it made better sounds
    Who’s going to experiment with aftermarket exhaust/pipe/ muffler??
    #10 artieb, Apr 26, 2024
    MIkeDr likes this.
  11. aforkosh
    aforkosh Active Member
    413
    261
    Oakland, CA
    2023 Prius
    I don't have a problem comfortably reaching the knob, but maybe my arms are longer than most.
  12. o_intent
    o_intent Junior Member
    55
    2023 Prius Prime
    XSE Premium
    Or, they could have avoided all the nonsense and did what they did on the Crown. Image3.jpg
    ...And why not, you already took the gauge/HUD from the BZ4X, you ain't above going to the parts bin Toyota!
    deev likes this.
  13. HacksawMark
    HacksawMark Active Member
    439
    287
    Oregon
    2023 Prius Prime
    XSE
    I recall when doing my research before buying the Prime was that the 12 inch screen could be controlled from the steering wheel inputs rather than the volume knob. I think it makes a little sense. I only use the knob to turn the radio on and off. Anything else, I just use the touchscreen.
    deev likes this.
  14. Sharol
    Sharol Member
    127
    60
    Kansas, USA
    2023 Prius
    There is a volume control on the steering wheel. It only makes sense to have the passenger one where he/she can reach it.
