Inner tie rod torque spec
Discussion in 'Gen 2 Prius Main Forum' started by jlm1983, Oct 9, 2017.
  1. jlm1983
    jlm1983 New Member
    AR
    I''m replacing the inner and outer tie rods on my 06 and I can't seem to find the torque specs for the inner tie rod. Found a thread on here that listed the outer as 36ft.-lbs but can't find inner. If anyone knows I would greatly appreciate it.
    52,406
    it should be in the service manual.
  3. jlm1983
    jlm1983 New Member
    AR
    I don't have access to a service manual as far as I know.
    52,406
    $15. for two day downloadable at toyota technical info.
  5. ChapmanF
    18,570
    Surely bisco has enough posts to be allowed to include a url? techinfo.toyota.com ...
  6. jlm1983
    jlm1983 New Member
    AR
    Thanks! I appreciate all the help.
    Raytheeagle likes this.
  7. AndyFromWI
    AndyFromWI Junior Member
    37
    Cumberland, WI
    Inner Tie Rod torque for a Gen2 Prius is:
    61 ft pounds if you are not using the SST Tool
    44 ft pound using the SST tool
    I'm assuming the SST (special service tool) is the one with the clips so you can hook up a torque wrench directly (the 44lbs)
    vs using the muffler clamp type adapter where the torque wrench hooks outside the diameter of the inner tie rod end.
    I just did the inners on a 2005 prius.
    What a pain to try and get the boots back on with the original clamps. In hind sight I should have just use screw type hose camps to hold the inner boots.
    -andy
    skorpyo33 likes this.
  8. timespell
    timespell Member
    53
    40
    Tully, NY
    Hi Andy, What tool did you use to remove the inner tie rod? How easy or hard was it to loosen it?
  9. skorpyo33
    skorpyo33 Junior Member
    30
    Sebastian, FL.
    Would this apply to 2010 3rd gen prius as well?
